7 members (Otto Skorzeny, dt235sd, Cosmo, Hanks custodian, klhansen, JW51, Lostbuthaulinass), 105 guests, and 2 robots.
Topics128,059
Posts1,055,825
#199330 01/26/2006 3:55 AM
Y
Junior Member
Junior Member
Y Offline
I can't figure out how to get the wiper arms off of my 51 6400, HELP.
1951 6400
1954 6100 dump
2 1962 IHC scouts
#199331 01/26/2006 4:40 AM
Shouldn't they just pry off?
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
#199332 01/26/2006 5:01 AM
i am not sure if my truck is the same, i have 61, but i just used a screwdriver to pry them off of the splines. it took some patience and care, but it worked.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#199333 01/26/2006 7:16 PM
I think their is a latch type of deal that you have to get the screw driver on and then pop/pry off...Fred
Redryder pix
My Hotrod
#199334 01/26/2006 7:26 PM
My '54 has a small retainer clip that needs to be pried "open" first. While holding this open, I put pressure on opposite sides of the arm near the shaft so that it wouldn't bind.
#199335 01/26/2006 11:39 PM
I had to replace both wiper arms recently and as tlorber mentions the clip is on the arm side. I used a lil' WD40 lifted the opposite side than the arm while using a small screwdriver to hold the clip side outwards. [img]http://members.shaw.ca/magnolia/images/wiper-arm.jpg[/img]
After it was loosened a bit I moved it until it lifted off.
1958 Chevy 1/2 ton Apache Stepside Longbed
Never trust a driver with a collision shop courtesy car
Photo Album
#199336 01/26/2006 11:45 PM
so this little clip just pops up? and then you pull off the arm....Fred
thanks for the pix
Redryder pix
My Hotrod
#199337 01/27/2006 12:01 AM
It wasn't easy on the passenger wiper arm. I had to walk away atleast once. When the clip began to move and I could get it above the smooth area into the wider area of the "whatchamacallit", it started to work outwards. Once over the lip I wiggled it off. I think the WD40 helped and working that clip a bit also got it loosened up.
Photo Album
#199338 01/28/2006 3:16 AM
They make a tool that works backward from pliers that really helps in removing wiper arms. Usually on a "Help" or KD rack at the bigger parts stores and not real pricey. One trick we use is to use a bondo spreader to pry a screwdriver against because it will cushion the paint job a lot better that masking tape or shop towel.
Evan
