| | | Forums66 Topics128,068 Posts1,055,882 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 37 Junior Member | | Junior Member Joined: Oct 2005 Posts: 37 | I can't figure out how to get the wiper arms off of my 51 6400, HELP.
1951 6400 1954 6100 dump 2 1962 IHC scouts
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Shouldn't they just pry off? | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | i am not sure if my truck is the same, i have 61, but i just used a screwdriver to pry them off of the splines. it took some patience and care, but it worked.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I think their is a latch type of deal that you have to get the screw driver on and then pop/pry off...Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | My '54 has a small retainer clip that needs to be pried "open" first. While holding this open, I put pressure on opposite sides of the arm near the shaft so that it wouldn't bind. | | | | | Joined: Aug 2005 Posts: 183 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 183 | I had to replace both wiper arms recently and as tlorber mentions the clip is on the arm side. I used a lil' WD40 lifted the opposite side than the arm while using a small screwdriver to hold the clip side outwards. [img] http://members.shaw.ca/magnolia/images/wiper-arm.jpg[/img] After it was loosened a bit I moved it until it lifted off. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | so this little clip just pops up? and then you pull off the arm....Fred
thanks for the pix Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Aug 2005 Posts: 183 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 183 | It wasn't easy on the passenger wiper arm. I had to walk away atleast once. When the clip began to move and I could get it above the smooth area into the wider area of the "whatchamacallit", it started to work outwards. Once over the lip I wiggled it off. I think the WD40 helped and working that clip a bit also got it loosened up. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | They make a tool that works backward from pliers that really helps in removing wiper arms. Usually on a "Help" or KD rack at the bigger parts stores and not real pricey. One trick we use is to use a bondo spreader to pry a screwdriver against because it will cushion the paint job a lot better that masking tape or shop towel.
Evan
