0 members (), 97 guests, and 2 robots.
Topics128,127
Posts1,056,679
Members48,452
#199119 01/24/2006 12:20 AM
Junior Member
Junior Member
I am looking for some plain old steel wheels with an eight lug pattern. Does anyone know what year range late model chevy or ford wheels will bolt up with no offset issues?
Also if I am running the original drums, do I need to run 16" wheels or will 15" work?
Split rims have got to go.
U
U Offline
The stock wheels off my '82 C20 fit on my '66 C20 with no problems. They are 16". Best thing is, you can pull them from the local salvage yard with tires for less than $100.00. I think you would have to go aftermarket to get 8 lugs in 15".
Scott
Life is good. Keep on playing.
Dodge 8 bolts will fit too,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Too bad you are so far away. I have 4ea. 8 x 16.5 chevy rims, free for the taking!
