Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (55shaker, baldeagle, Otto Skorzeny, Greg_H), 30 guests, and 0 robots.
Topics128,004
Posts1,055,246
Members48,418
#19861 04/27/2005 3:03 PM
i have a pertonix unit installed in my distributor. would a MSN spark enhancer be of value on it or even work? ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#19862 04/27/2005 4:29 PM
sorry i had a senior moment, MSD ing. ron
2017 Buick Encore
See more pix
#19863 04/28/2005 1:56 AM
Hey WE b,
Page 39 of the MSD Ignition Wiring Diagrams and Tech Notes book shows how to do it. You can use a MSD 6 box with a Pertronix kit in the following manner:
THE THIN BLACK WIRE FROM THE MSD BOX GOES TO THE NEGATIVE SIDE OF THE COIL
THE ORANGE WIRE GOES TO THE POSITIVE SIDE OF THE COIL.
THE MAGNETIC PICKUP IS NOT USED.
THE HEAVY BLACK WIRE GOES TO THE NEGATIVE SIDE OF THE BATTERY.
THE HEAVY RED WIRE GOES TO THE POSITIVE SIDE OF THE BATTERY.
THE WHITE WIRE FROM THE MSD BOX IS CONNECTED TO THE BLACK WIRE FROM THE PERTRONIX KIT IN THE DISTRIBUTOR.
THE THIN RED WIRE FROM THE MSD BOX IS TAPPED INTO THE RED WIRE THAT GOES BETWEEN THE PERTRONIX KIT TO THE IGNITION SWITCH. BY TAPPED, I MEAN NOT SPLICED, JUST A "T" CONNECTION. THE DISTRIBUTOR TO IGNITION SWITCH CIRCUIT REMAINS INTACT.
I hope that this helps.
#19864 04/28/2005 3:42 AM
thanks, but would it be worth doing? each thing i do to the engine i am trying to improve the performance, but if i don't need to spend the money i don't want to. ron
2017 Buick Encore
See more pix
#19865 04/28/2005 11:07 AM
knuckle head
knuckle head
It won't make any difference on a stock engine.A multispark ignition might help mask carb problems at part throttle,but it won't add power.On hi compression engines running lean mixtures, nitrous or supercharging,the MSD boxes are a benifit.
#19866 04/28/2005 11:21 AM
I have a 1956 235 with a stock distributor in my 1950 bolt. My MSD box makes it start faster, and run smoother. I have no experience with Pertronix, but MSD is worth the money.
#19867 04/28/2005 11:36 AM
knuckle head
knuckle head
3100,my experience is different,I noticed no difference between properly adjusted points in a distributor with no worn parts and when I added a MSD 6A multi spark system.
Every situation is different,a real world test like we have done is the only way of knowing if it's works.
I found the MSD ignition ate up the spark plugs pretty fast, have you noticed that?
#19868 04/28/2005 4:24 PM
Fasty, I gapped the plugs out to 55 thousands, out of a MSD maximum recommendation of 60 thousands. So far no problems. I also have to report that I have only out on a little over 300 miles since I installed the MSD box.
I also have installed Magnecor wires to handle the increased spark load. They went in pre-MSD, and were also a big improvement over regular spark plug wires.
It fires up faster, and runs smoother.
#19869 04/28/2005 4:26 PM
BTW, my coil is the 45,000 volt yellow Accel model. It works, but if I had to do it all over again, I would have used an MSD coil as well.
#19870 05/01/2005 8:58 PM
Not to downgrade all those high end, expensive, ignition goodies, I've beent running all stock and original parts in my 62 '235 and it tends to start faster and run as smooth or more so than my "new" vehicles. Therefore, I'm sticking with stock ignition as I add my exhaust goodies.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
