0 members (),
59
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | What type of sand blasting media should I use to clean up brake drums, brake back plates, etc.... And can you tell me where you purchase these. Thanks. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | #4 blasting sand will do just fine on those parts. Many of the older independent hardware places either carry the sand or can get it for you. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | evac34,
I am guessing you are using either a siphon blaster or a small pressure pot...the "in the driveway type".
Your building supply center should have sand in 90# bags labeled 20 mesh (coarse) or 30 mesh (less coarse). If this is open blasting, wear a mask and don't dust out the neighbors.
Stuart | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Dont. Use. Sand. :mad:
Go to a farm supply or industrial supply and get some glass bead or aluminum oxide or crushed garnet for blasting. Sand contains free silica, which can lead to silicosis unless you're using a VERY good respiration system. Not worth the risk, blasting media isn't expensive. | | | | | Joined: Nov 2005 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 67 | I used garnet on mine. The finer the sand, the less profile you get. This is always the best when blasting panels. Brendon | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Listen to GMCpanel. I use crushed walnuts, but I think you need something a little stronger like the aluminum oxide or garnet. | | | | | Joined: Dec 2005 Posts: 112 Member | | Member Joined: Dec 2005 Posts: 112 | not mean'n to interupt good advise to evac 34 but was interested in the purchase of a "in the drive way type" and saw those small siphon blasters(around 50$)in the j.c. whit. catalog,anybody using this type or suggest a descent type to use for small jobs,wheels,rear ends,etc.
1949 Styleline Special 1972 K5 Blazer
| | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | There is a thread on this site on building a sandblaster that supposedly uses less air than a pressure system and works better.
Before you start sandblasting yourself I suggest calling the nearest monument company, the people that make headstones..., they can blast your stuff for cheap and fast. The company near me charges $70/hour and can do 2 brake drums in 5 minutes or less with their huge compressor and sandblasting booth.
I paid $100 for them to blast my entire cab, inside and out, plus a lot of other parts.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | burntclutch, NM51 does not speak with forked tongue. If you want a setup yourself I would say this, even the smallest sandblaster uses vast quantities of air..waiting for the Harbor Freight 2CFM unit to pump back up can lead to anal implosion. Sears used to make a small syphon feed unit that held about 1/3 of a bag of sand (#90). It was small enough to hide in the corner of the shop, but would clean up a brake drum or exhaust manifold pretty quick. As my dear old dad used to say.."take my advice and suit yerself". Stuart | | | | | Joined: Nov 2005 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 67 | NM51 is right. If you already have the small blasting kit, then i suggest you buy a 25kg bag of garnet. The bags we use are labeled GN 030-060. The finer the better. There is very minimal dust from garnet. However for parts like that, if you can get them blasted with someone who does that every day you could get them put in with another job, we usually charge a 4 pac off JD for the job brendon | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | A 4 pack of Jack Daniels..........whoa nellie!
Down-under-Stu | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I use a pressure pot and an 50 gal. 7hp air compressor and it still has a hard time keeping up. I stopped doing it because of the mess and that the darn nozzle keeps getting clogged with foreign matter that always gets in your media. I will use it as a last resort. I am trying to find a media blaster near Vero Beach Florida, though I never thought of a monument company. I will be calling a few tomorrow. There should be plenty of those companies around here! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I have the 90 lb siphon blaster I bought from Eastwood about 3 years ago. It does pretty good with my 80 gal 7hp 175cfm compressor but pressure blasting is better. I recently seen where Eastwood now has a small pressue blaster for around the same price I paid for a siphon blaster back then. I think the pressure blasters were $119. The small stuff I use glass beads and I'm lucky enought to have one of the Skat-Blast cabinets to do it with. I love it and the dust is sucked out into a canister and bag. | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | NM51, You were right, the first monument company I called was happy to do extra blasting. I thought they would think I was crazy! Thanks for the idea! A.chipmunk, what size is your Skat-Blast cabinet? Where did you get it? I was looking at a bench model from Eastwood but it seems too small. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | jomichael, Make sure the monument company knows the difference between blasting sheet metal and blasting Italian marble... Stuart | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Yeah, i am only giving him the frame, axles, transfer case, etc. Then I will give him an old fender and see what happens. He said he does stuff for a chopper shop. We will see! Thanks for the advice. | | | | | Joined: Jan 2006 Posts: 15 Junior Member | | Junior Member Joined: Jan 2006 Posts: 15 | Boy, you guys are good. I never would have thunk of a monument company. Got one right in town. Guess I'll start haulin' parts into'em. -thanks | | | | | Joined: Jan 2006 Posts: 8 Junior Member | | Junior Member Joined: Jan 2006 Posts: 8 | Yeah. This is the best darn website. We have a monument maker here in Walla Walla, and I bet they'll be glad to do the frame on my old '51. Thank you. | | |
