0 members (), 33 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,424
#197276 01/05/2006 12:01 PM
Just had them hauled home yesterday. Two '48 chevy dump trucks. They both have steel dump bodies, one is 8'X 9', the other is 7' X 8'. The name plate on the side of the hood says "Loadmaster". How do I tell if they're 1,1-1/2 or 2 ton? Also how do I find out what size engines are in them, 216 or 235?
#197277 01/05/2006 1:31 PM
I
I Offline
Get the VIN# from inside the drivers door and run it throug the VIN cruncher
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#197278 01/05/2006 1:58 PM
I know the man to talk to....48bigtrucks his name is Scott. check out his BOLTS and he will know the answer to your questions.
My 48 Loadmaster
My other 48 Loadmaster
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
#197279 01/06/2006 4:16 AM
I heard my name! In the last 58 years your trucks could have had many parts swapped around so there's no real way to tell exactly what you have. If it has a single speed rear it's more than likely a 1 1/2 ton. Most 2 tons had the 2 speed rears. Most 1 1/2 tons started out with 7.50 x 20' tires on them with about a 5' wide rim. 8.25 x 20's x a 6" rim for the 2 tons. The term "Loadmaster" also usually indicated a 1 1/2 ton. I'm not an expert on this since I've never had a 2 ton so some of this info mat be flawed.
To find out what engine you have, find a flat spot on your block just above and in front of your starter. Clean this area well with a wire brush and list those numbers on this post and we'll try to decipher them for you.
Post some pictures of them for us so we can see what we're talking about. Welcome to the Stovebolt,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#197280 01/06/2006 6:41 AM
Here a link you may find helpful if you have the serial number plates on them.
http://www.stovebolt.com/techtips/series.htm
You never have enough, til you have too many!
