4 members (Otto Skorzeny, baldeagle, stlcardinalsguy, Ridgeback), 37 guests, and 4 robots.
Topics128,012
Posts1,055,318
Members48,419
#197134 01/04/2006 2:41 AM
I bought a new heavy duty 4 core radiator from Jim Carter for my 63 with a sbc. The radiator seems like a good piece and fits the truck. The problem is that the thermostat housing neck is 11/2" and the upper neck on the new radiator is 13/4" and the hose that they sold me is 11/2" ID on both ends. Has anybody run into this problem before and if so what have you done? Jim Carter is closed all week so I haven't called them yet, but I have a pretty good idea what their response is going to be. I can drive to either Jim Carter or Chevy Duty in about 20 minutes or LMC Truck in about 45. I can only imagine how frustrating it must be for you guys that have to order everything.
#197135 01/04/2006 3:03 AM
Socket Breaker
Socket Breaker
Is it possible to change the thermostat housing?
It just bolts onto the top of the intake, right?
Hmn...
-W
#197136 01/04/2006 3:14 AM
Yeah, it is frustrating to order. I just bought two doors and two bedsides and was nailed with $350 in shipping! The 20% discount helped though.
#197137 01/04/2006 3:20 AM
Just take it to your local parts house and tell them/show them what you need. They make a lot of hoses with different sized ends, just have to match them up.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#197138 01/04/2006 3:35 AM
I have thought of changing the thermostat housing, maybe use a housing from a bbc. The problem is that until I find a hose with the correct configuration with 13/4" ID on both ends, changing the thermostat housing won't solve anything. So far everything that they've shown me at the parts store has been 11/2" ID. I called Jim Carter yesterday and the recording said that they were closed until 1-7-06.
