| | | Forums66 Topics128,012 Posts1,055,321 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 70 New Guy | | New Guy Joined: Nov 2003 Posts: 70 | I bought a new heavy duty 4 core radiator from Jim Carter for my 63 with a sbc. The radiator seems like a good piece and fits the truck. The problem is that the thermostat housing neck is 11/2" and the upper neck on the new radiator is 13/4" and the hose that they sold me is 11/2" ID on both ends. Has anybody run into this problem before and if so what have you done? Jim Carter is closed all week so I haven't called them yet, but I have a pretty good idea what their response is going to be. I can drive to either Jim Carter or Chevy Duty in about 20 minutes or LMC Truck in about 45. I can only imagine how frustrating it must be for you guys that have to order everything. | | | | | Joined: Feb 2002 Posts: 2,892 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,892 | Is it possible to change the thermostat housing?
It just bolts onto the top of the intake, right?
Hmn...
-W | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Yeah, it is frustrating to order. I just bought two doors and two bedsides and was nailed with $350 in shipping! The 20% discount helped though. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Just take it to your local parts house and tell them/show them what you need. They make a lot of hoses with different sized ends, just have to match them up. Scott | | | | | Joined: Nov 2003 Posts: 70 New Guy | | New Guy Joined: Nov 2003 Posts: 70 | I have thought of changing the thermostat housing, maybe use a housing from a bbc. The problem is that until I find a hose with the correct configuration with 13/4" ID on both ends, changing the thermostat housing won't solve anything. So far everything that they've shown me at the parts store has been 11/2" ID. I called Jim Carter yesterday and the recording said that they were closed until 1-7-06. | | |
