5 members (Bill Hanlon, Wickedbass, tclederman, Donf, TexasJim50), 55 guests, and 0 robots.
Topics128,075
Posts1,055,916
Members48,429
#196019 12/22/2005 8:04 PM
Since the wipers did not work when I purchased my truck, I don't know how they are supposed to work, other than running on engine vacuum. What do the two controls do on each motor do? One pulls in and out and the other screws in and out.
Thank-you,
Brian
#196020 12/22/2005 8:07 PM
I may be wrong but it seems on my 46 the one you pull turns on the wiper and the turn adjusts the speed. I am not sure if mine work as they should, when I give the truck gas they slow down and when I let off the gas they start working again.
Ed
#196021 12/22/2005 8:47 PM
yer right Ed, pull on, turn to slow down, but just pushing the gas accomplishes that faster grin because when you step on the gas the engine vacuum decreases - you can improve that behavior some by getting the fuel pump that has the vacuum assist pump on it
Brian - if yer's don't work at all you need to at least open the wiper motor and clean it out, and then grease the leather flap you find in there to help it seal and stay supple - may need to get it rebuilt
#196022 12/22/2005 9:39 PM
Red58
Thanks for the tip.
Ed
#196023 12/22/2005 9:49 PM
Thanks guys. I took the one motor apart and it was all gunked up, along with causing a significant engine vacuum leak because of a loose inlet tube. No wonder the engine ran better with the choke partially on.
Brian
#196024 12/22/2005 11:38 PM
Bill:
What kind of grease do you use on that wiper motor leather flap?
-Brendan
#196025 12/22/2005 11:58 PM
install a sealed coffee can w/ two small tubes soldered in situ. this helps w/ more vacuum volumn
Jim & Caroline
#196026 12/23/2005 1:46 PM
How do you remove the wiper motor? Is it just the big nut around the wiper shaft? My '40 GMC needs some attention too.
Steve
See my 1940 Canadian GMC:
http://community.webshots.com/user/ndnchf
#196027 12/23/2005 5:47 PM
Some where I read vasoline works pretty well, but I used motor oil so soften the leather seals, then went back with white lithiom grease, its pretty oily grease and seemed to work ok. Joe
#196028 12/23/2005 7:10 PM
yes on the white grease as Joe sez
Steve - yes the bezel nut is what holds the early ones on, with a little doober inside to hold the motor in the right position and keep from turning
you guys w/ vacuum motors should consider using the wipermans service - he bought out all the remaining stock from TRICO years ago and really does a good number on'em - work like new for ages after
#196029 12/25/2005 6:47 PM
If you send your wiper motor off to David Ficken, "the wiper man", you will not believe how much better it works. He's slightly higher than some others but will keep on the promised delivery schedule. Most of the vehicles we do just use the wiper once a year to pass state inspection but, if they actually use them we put an electric vacuum pump in them. It's compact so will fit most anywhere and makes vacuum wipers super since they are infinitely speed adjustable. These pumps are pricey new but so many new cars are having them, especially diesels, that used ones are getting reasonable.
Evan
