1 members (Peggy M),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 70 | ARE the grilles in 42-46 pickups all the same size? I'm not dumb, but I ain't seen a Chevy truck close up for nearly two score years I heard there's different size fenders, but grilles???
"After you skin yer knuckles, Mr Shifter ain't yer friend any more." 1942 Chevy 3/4 tonIn the Stovebolt GalleryPhoto Site1946 Chevy 5 window coupe/ute (new stray) 2000 Nissan Patrol 4x4 4.5l turbo diesel
| | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | as far as i know the grille is the same and the fenders are bigger on the big trucks because of the bigger tires. | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | The grille, Cab, and hood are all the same on everything.
The front fenders will also fit, but you will have to watch out. The larger trucks had bigger tires, and the wheel openings are larger on the big trucks. | | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | a men it will all fit except for the finders have bigger wheel openings
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 |
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Larger truck fenders also have a different curve where it meets the running board. A friend found some 3/4 ton 46 fenders, did not match the running board of the half ton. | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Originally posted by JiMerit: Larger truck fenders also have a different curve where it meets the running board. A friend found some 3/4 ton 46 fenders, did not match the running board of the half ton. Huh. That, I did not know. | | | | | Joined: Jul 2005 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 70 | MANY THANKS guys, that answers my question perfectly. Just going down the shed now to convert a Canadian plastic dog kennel into a sandblast cabinet. The things us guys get uo to!
