10 members (JW51, Tinker5, TUTS 59, wilbur53, 3B, jupitor, GMCJammer51, J Lucas, walter74, dt235sd), 158 guests, and 1 robot.
Topics128,080
Posts1,055,952
Members48,430
#195707 12/18/2005 3:42 PM
Z
Z Offline
ARE the grilles in 42-46 pickups all the same size? I'm not dumb, but I ain't seen a Chevy truck close up for nearly two score years eek
I heard there's different size fenders, but grilles???
"After you skin yer knuckles, Mr Shifter ain't yer friend any more."
1942 Chevy 3/4 ton
Photo Site
1946 Chevy 5 window coupe/ute (new stray)
2000 Nissan Patrol 4x4 4.5l turbo diesel
#195708 12/18/2005 4:10 PM
as far as i know the grille is the same and the fenders are bigger on the big trucks because of the bigger tires.
The crew that works on the \'42 --Sara, Hannah and Abby
#195709 12/18/2005 5:05 PM
The grille, Cab, and hood are all the same on everything.
The front fenders will also fit, but you will have to watch out. The larger trucks had bigger tires, and the wheel openings are larger on the big trucks.
#195710 12/18/2005 11:27 PM
a men it will all fit except for the finders have bigger wheel openings
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
#195711 12/19/2005 12:13 AM
yep
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
#195712 12/19/2005 12:22 AM
Larger truck fenders also have a different curve where it meets the running board. A friend found some 3/4 ton 46 fenders, did not match the running board of the half ton.
1946 1/2-Ton Chevy
#195713 12/19/2005 6:56 AM
Quote
Huh. That, I did not know.
#195714 12/20/2005 3:15 AM
Z
Z Offline
MANY THANKS guys, that answers my question perfectly.
Just going down the shed now to convert a Canadian plastic dog kennel into a sandblast cabinet.
The things us guys get uo to! wink
1942 Chevy 3/4 ton
Photo Site
