5 members (55shaker, Phak1, 49fastback, Biermann, Jaison), 106 guests, and 2 robots.
Topics128,137
Posts1,056,747
Members48,454
Junior Member
Junior Member
Is there a good way to clean up the frame on a 1953 chevy 1/2 truck and get it ready to paint without having to media blast??/
thanks for any help
Never Let Them Go
I had mine blasted for a $100. I wouldn't even consider doing it myself when I got it cleaned that cheap.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I have done both my 59 truck and my 47 cj2a with a big grinder and a knotted cable wire brush. In fact - it took like 3-4 brushes for each of them. I preferred it because I didn't want to have the media coming out all over the place. Using small cup brushes you can get in the nooks and crannies.
I then sprayed it with metal-prep (just posphoric acid) and then put zero rust on the truck and chassiskote on the heep. Both are lasting good. I'd give the edge to chassiskote as its harder.
However, having it done is a lot easier. And for $100, that was less than the grinder, wheels, and time spent.
