11 members (Hotrod Lincoln, J Lucas, Youngin' Tut 59, 5 Window 9434, lumbersawyer, klhansen, DougH6100, MNSmith, Pete1946, Shade Baby, 1 invisible),
88
Mod | | | Forums66 Topics128,139 Posts1,056,762 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 28 Junior Member | | Junior Member Joined: Dec 2005 Posts: 28 | Is there a good way to clean up the frame on a 1953 chevy 1/2 truck and get it ready to paint without having to media blast??/
thanks for any help
Never Let Them Go
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I had mine blasted for a $100. I wouldn't even consider doing it myself when I got it cleaned that cheap. Scott | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I have done both my 59 truck and my 47 cj2a with a big grinder and a knotted cable wire brush. In fact - it took like 3-4 brushes for each of them. I preferred it because I didn't want to have the media coming out all over the place. Using small cup brushes you can get in the nooks and crannies.
I then sprayed it with metal-prep (just posphoric acid) and then put zero rust on the truck and chassiskote on the heep. Both are lasting good. I'd give the edge to chassiskote as its harder.
However, having it done is a lot easier. And for $100, that was less than the grinder, wheels, and time spent. | | |
