| | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 23 Apprentice | | Apprentice Joined: Nov 2005 Posts: 23 | Hello,
I am posting this in the general forum since it seems to get the most traffic. Sorry if that isn't correct. I am new to this board and new to old trucks as well. I just acquired a '51 3/4 ton that is in pretty sad shape. It was sitting in a salvage yard with chest high weeds surrounding it. My plans for now are to get it into driver condition for as little cash as possible by doing the work myself and using shadtree junkyard swapping.
Anyway, to my first questions. I have successfully removed the driver side door but the flanged part of the hinge that the bolts pass through did not survive-they literally crumbled off. It seems that repop hinges are not available, so I have already considered doing suicide doors. Any good information for this swap? Or does someone have a source for stock hinges?
Secondly, the pass side door will not open. I'm sure the latch is frozen shut with rust. Any tips on getting the door to open?
Thanks in advance for your help!
Bret | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Bret,
Don't have an answer to either of your questions, but wanted to jump in and say...
Welcome to the Stovebolt. | | | | | Joined: May 2005 Posts: 147 Shop Shark | | Shop Shark Joined: May 2005 Posts: 147 | Welcome Bret...
Hmmm, I had the same problem with my old snow-plow truck. The air chisel worked wonders on getting to the latch, from the outside. However I would not recommend this if you plan on reusing the door. If you can't reach the latch from inside, you cut a hole near it from the inside. May be easier to repair panel....
-RT1 | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Can you remove the inner panel from the inside to see what might be hanging up??
And another obvious question... is the door locked?? | | | | | Joined: Nov 2005 Posts: 23 Apprentice | | Apprentice Joined: Nov 2005 Posts: 23 | I wish I could post a picture. This truck sat in the weather for years with no glass. There is a very weathered licemse plate from North Dakota from '62 on the front plate bracket. The truck is gutted, so there is no panel to remove. I have not figured out the latch/lock mechanism yet. The driver side is frozen with rust, so it is not a good reference. Can someone point me to a diagram of the latch? | | | | | Joined: May 2005 Posts: 147 Shop Shark | | Shop Shark Joined: May 2005 Posts: 147 | | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | welcome to the bolt... keep you a BFH around.. best of luck........Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | .Welcome, look at the other door side that opens..Should be able to move latch from inside to open door + BFH.ha ha
dan-pa
| | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | go buy some wd 40 and soke the pi@@out of it and thed try agine repite as nessary till open
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | PB (rust) Blaster is even better. But the best I have found is a regular blue flame speed wrench. I.e. heat the fastners up to dull red hot then let it sit. You can also quench with a bit of water. Then usually that breaks the rust bond and you can un-do. | | | | | Joined: Feb 2002 Posts: 2,897 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,897 | click on 'Links' at the top of the page here, then go to 'Parts'. For other websites with information... look under truck sites and street rod. http://www.hotrodders.com - is a great forum for all kinds of body mods. -W | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | bowtie bits has rebuilt door hinges last time i looked. try seachin out the links page lots of useful info there. also, welcome aboard.- p.s. a bfh and pb blaster are great friends
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: Jun 2005 Posts: 49 Junior Member | | Junior Member Joined: Jun 2005 Posts: 49 | douse it with PB blaster, let it sit overnight, do It again in the morning, again the next night... eventually it will loosen | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Take the "open" door apart to figure out what needs to be done to the other door. You need to take it apart sooner or later to "refreshen" it and properly lubricate it anyway. It may be that the door itself is stuck or jammed into the opening too. May need to crawl inside and use your feet against the door as persuasion too, Scott | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you have a die grinder with a small bit, go in behind the rear door post and cut off the four nuts that hold the striker plate on. then the door will open with the striker plate still in the latch. This option does the least damage. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Thanks for the pictures. I think that there may be some speed differences between your projects!
Door hinges come up on Ebay fairly regularly. If they are not fully rebuilt, they usually don't go for too much because of the shipping weight. | | |
