2 members (TPR57C, 1955 1 Series), 360 guests, and 3 robots.
Topics128,159
Posts1,057,033
Members48,460
#194443 11/28/2005 2:13 AM
would I be correct on the 49 to 54 rear half-ton fenders being the same.. I may replace my right rear one..........thanks..Fred
Redryder pix
My Hotrod
#194444 11/28/2005 2:30 AM
Anonymous
Unregistered
Anonymous
Unregistered
correctamundo except there is a left and a right.
#194445 11/28/2005 2:47 AM
How about 47 2nd series thru 55 1st series? Would that work?
#194446 11/28/2005 3:39 AM
Anonymous
Unregistered
Anonymous
Unregistered
That would work also. The rear fenders from the 47-55.1 Advance Design trucks are identical for 1/2 ton up through 1 ton to my understanding.
#194447 11/28/2005 3:53 AM
Joker, how did you scrunch your fender?
#194448 11/28/2005 4:24 AM
not really scrunched,,, the fender had some bondo work before I bought the truck 8yrs ago, has cracked, I had it repaired again about 4 yrs ago and it has cracked again,, just thought that I might replace it rather then repair it,,still doesn't look to bad,, just thinking ahead about what I might do in the spring.........thanks for the response to all of you..........Fred
Redryder pix
My Hotrod
#194449 11/28/2005 5:46 AM
solid fenders are a dimadozen... get a couple of them...
Another quality post.
Real Trucks Rattle
#194450 11/28/2005 6:14 AM
Last pair of solid AD fenders I sold went for just over $300 for the pair.
A '51 3/4 ton set and a '52 1/2 ton set were identical.
#194451 11/28/2005 4:14 PM
Quote
I'll take two dozen. No, three. Yes I'll take three dozen!
#194452 11/28/2005 4:23 PM
Fred- Does that fender have a brace to the box? I can't remember what the AD's have. It sounds like the fender might be flexing or vibrating too much and causing the mud to crack.
To be long remembered as he's cruising in
The Passing Lane
#194453 11/28/2005 4:46 PM
Barry, I will check, thanks for the tip.. regards.Fred
Redryder pix
My Hotrod
#194454 11/28/2005 5:34 PM
Anonymous
Unregistered
Anonymous
Unregistered
I hve two extra braces if they are needed.
#194455 11/29/2005 12:55 AM
Rusty Rod, please tell us all where we can get those fenders for a "time a dozen" we WANT THEM, like now!!
#194456 11/29/2005 12:58 AM
Barry Weeks, the 471st thru the 55nd has a brace from the rear fender to the frame, not to the box.
#194457 11/29/2005 1:35 AM
If those fenders have no bead cracks, aren't rusted where they bolt to the running boards, haven't been run with mud or snow chains with a loose link that knobbied them all up from the inside, then I'll give you $1000 for your ten cent investment.
Evan
#194458 11/29/2005 1:42 AM
I
I Offline
Sorry a little off topic but oh well...
My box has braces from the top of the fender to the box is this a manufactured thing or a common aftermarket change and is it okay to put on a 1950 3100 Chevy. Also how hard are they to remove and if you do does this operation screw up your fenders??
Thanks for the help
Erik Berg
1952 Chevy 3100
#194459 11/29/2005 5:23 AM
Anonymous
Unregistered
Anonymous
Unregistered
There is a middle brace that is riveted to the middle fender lip and secured to the box via one of the fender bolts. I have seen several ADs that have this brace removed as the owners did not like the two rivet heads showing on the fender.
