7 members (Gray_Ghost, Phak1, Buckeye998, 1955 1 Series, Otto Skorzeny, SmalltownTRKGuy, Pre '68 Dave),
140
Mod | | | Forums66 Topics128,164 Posts1,056,983 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | would I be correct on the 49 to 54 rear half-ton fenders being the same.. I may replace my right rear one..........thanks..Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | correctamundo except there is a left and a right. | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | How about 47 2nd series thru 55 1st series? Would that work? | | | | | | Anonymous Unregistered | | Anonymous Unregistered | That would work also. The rear fenders from the 47-55.1 Advance Design trucks are identical for 1/2 ton up through 1 ton to my understanding. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Joker, how did you scrunch your fender? | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | not really scrunched,,, the fender had some bondo work before I bought the truck 8yrs ago, has cracked, I had it repaired again about 4 yrs ago and it has cracked again,, just thought that I might replace it rather then repair it,,still doesn't look to bad,, just thinking ahead about what I might do in the spring.........thanks for the response to all of you..........Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | solid fenders are a dimadozen... get a couple of them...
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Last pair of solid AD fenders I sold went for just over $300 for the pair.
A '51 3/4 ton set and a '52 1/2 ton set were identical.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Rusty Rod: solid fenders are a dimadozen... get a couple of them... I'll take two dozen. No, three. Yes I'll take three dozen!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Fred- Does that fender have a brace to the box? I can't remember what the AD's have. It sounds like the fender might be flexing or vibrating too much and causing the mud to crack. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Barry, I will check, thanks for the tip.. regards.Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I hve two extra braces if they are needed. | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | Rusty Rod, please tell us all where we can get those fenders for a "time a dozen" we WANT THEM, like now!! | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | Barry Weeks, the 471st thru the 55nd has a brace from the rear fender to the frame, not to the box. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | If those fenders have no bead cracks, aren't rusted where they bolt to the running boards, haven't been run with mud or snow chains with a loose link that knobbied them all up from the inside, then I'll give you $1000 for your ten cent investment.
Evan
| | | | | Joined: Nov 2005 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 21 | Sorry a little off topic but oh well... My box has braces from the top of the fender to the box is this a manufactured thing or a common aftermarket change and is it okay to put on a 1950 3100 Chevy. Also how hard are they to remove and if you do does this operation screw up your fenders??
Thanks for the help | | | | | | Anonymous Unregistered | | Anonymous Unregistered | There is a middle brace that is riveted to the middle fender lip and secured to the box via one of the fender bolts. I have seen several ADs that have this brace removed as the owners did not like the two rivet heads showing on the fender. | | |
