4 members (Gdads51, wilbur53, WICruiser, HandyAndy), 119 guests, and 7 robots.
Topics128,095
Posts1,056,077
Members48,433
Trying to remove lower control arms from my '65. I'm trying to press the ball joint stud out of the steering knuckle with a tool similar to that in the manual. Doesn't seem to be budging and I've got so much torque on the wrench, I'm afraid the wrench is gonna break. Any tips on getting these things out of the knuckle?
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
Load it like you describe then smack the screw with a hammer, or smack the control arm eye where the stud passes through.
Alternatively, you can use a pickle fork but it tears up the boot, a non-issue if you are replacing them.
let your suspension hang put the ball joint nut back on 4 or 5 turns then take a large hammer or slege hammer and hit the lower balljoint boss on the spindle this should free it up.works for me every time.
