| | | Forums66 Topics128,088 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Trying to remove lower control arms from my '65. I'm trying to press the ball joint stud out of the steering knuckle with a tool similar to that in the manual. Doesn't seem to be budging and I've got so much torque on the wrench, I'm afraid the wrench is gonna break. Any tips on getting these things out of the knuckle? Thanks, -David | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Load it like you describe then smack the screw with a hammer, or smack the control arm eye where the stud passes through.
Alternatively, you can use a pickle fork but it tears up the boot, a non-issue if you are replacing them. | | | | | Joined: Oct 2005 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 32 | let your suspension hang put the ball joint nut back on 4 or 5 turns then take a large hammer or slege hammer and hit the lower balljoint boss on the spindle this should free it up.works for me every time. | | |
