4 members (baldeagle, 78buckshot, JW51, moparguy), 83 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#191912 10/24/2005 12:31 AM
Its ready for the road. What I need is a picture of the way the wire connects to the carb. There is a place for the cover but I cant find where the center wire connects.
Thanks.
1951 1.5 ton 4400
#191913 10/24/2005 2:51 AM
Greg - here\'s the layout - most folks have a cotter pin in the throttle linkage where there needs to be the special clip shown to hold the rod in place, and the cable goes thru the hole and is held by the little screw clamp so the linkage can move while the cable slides in the hole - when you pull the hand throttle it pulls up the linkage
clear enuff? grin
#191914 10/24/2005 2:54 AM
This might help.
Yesterday I drove my truck 234 miles and used my T knob for at least 1/2 of the trip.
throttle cable to carb hook up
Craig
#191915 10/24/2005 3:01 AM
Thanks Bill that is what I needed.
cmayna, I cant open your page tonight it is blocked by the company I work for and will look at it from home tomorrow.
Thanks guys.
1951 1.5 ton 4400
#191916 10/24/2005 4:27 PM
red58,
Hey that's a pic of my throttle linkage smile
Craig
#191917 10/25/2005 3:07 AM
Craig - now I know where that came from!!
passed this question up at first because I couldn't find a link to where I'd seen a pic of the setup, but then remembered I had it on my HD - saved it to show a couple on mechanic friends so they can keep an eye out for any of those clips, which usually have been long removed and lost
got the link to yer webshots now, so don't close yer account! grin
#191918 10/25/2005 3:24 AM
red58, are those special clips?
I found some clips that look like they might fit but might be a little small.
1951 1.5 ton 4400
#191919 10/25/2005 3:58 AM
greg - they were commonly used on various linkages way back to keep the arm from slopping around in the hole, but most get chucked and replaced w/ cotter pins - needs to be the right size for the diameter of the shaft and the size of the hole, but if you've got some close they may work - only way to do the throttle linkage as the hole needs to be free and kept in the right position so the cable can slide freely when you use the pedal
#191920 10/25/2005 4:06 PM
Here's a schematic of the entire linkage setup I found on another website. Maybe it will help.
linkage set up
Craig
#191921 10/25/2005 4:19 PM
Craig, that's great. Been looking for something like that. Thanks for posting it. cool
