| | | Forums66 Topics128,024 Posts1,055,390 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 50 | Its ready for the road. What I need is a picture of the way the wire connects to the carb. There is a place for the cover but I cant find where the center wire connects. Thanks.
1951 1.5 ton 4400 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Greg - here\'s the layout - most folks have a cotter pin in the throttle linkage where there needs to be the special clip shown to hold the rod in place, and the cable goes thru the hole and is held by the little screw clamp so the linkage can move while the cable slides in the hole - when you pull the hand throttle it pulls up the linkage clear enuff? Bill | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | This might help. Yesterday I drove my truck 234 miles and used my T knob for at least 1/2 of the trip. throttle cable to carb hook up
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Dec 2002 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 50 | Thanks Bill that is what I needed. cmayna, I cant open your page tonight it is blocked by the company I work for and will look at it from home tomorrow. Thanks guys.
1951 1.5 ton 4400 | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | red58, Hey that's a pic of my throttle linkage
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Craig - now I know where that came from!! passed this question up at first because I couldn't find a link to where I'd seen a pic of the setup, but then remembered I had it on my HD - saved it to show a couple on mechanic friends so they can keep an eye out for any of those clips, which usually have been long removed and lost got the link to yer webshots now, so don't close yer account! Bill | | | | | Joined: Dec 2002 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 50 | red58, are those special clips? I found some clips that look like they might fit but might be a little small.
1951 1.5 ton 4400 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | greg - they were commonly used on various linkages way back to keep the arm from slopping around in the hole, but most get chucked and replaced w/ cotter pins - needs to be the right size for the diameter of the shaft and the size of the hole, but if you've got some close they may work - only way to do the throttle linkage as the hole needs to be free and kept in the right position so the cable can slide freely when you use the pedal
Bill | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Here's a schematic of the entire linkage setup I found on another website. Maybe it will help. linkage set up
| | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Craig, that's great. Been looking for something like that. Thanks for posting it.  | | |
