Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Simon1954, KingG), 56 guests, and 4 robots.
Topics128,009
Posts1,055,297
Members48,419
#189468 09/14/2005 7:12 PM
I want to use the original hubcaps for my '60 1/2 ton. Having never seen one, though, and not having any of the original wheels, I don't know if these are the right wheels or not.
Can someone help me?
Auction link
[img]http://i21.ebayimg.com/01/i/04/d0/e4/76_1_b.JPG[/img]
#189469 09/14/2005 7:29 PM
I'm not for sure what sort of hubcaps a '60 uses.. but the earlier trucks (like the '46 thru early 50's trucks) need those little "square root" looking tabs on them for the hubcaps to clip on to.
If your caps just cover the lugnut area, then you probably need to have those "square root" tabs, too.
#189470 09/14/2005 7:46 PM
So you're saying I should be getting these instead:
[img]http://i19.ebayimg.com/01/i/04/70/a8/7b_1_b.JPG[/img]
#189471 09/14/2005 7:51 PM
They should work, but the 60 has the hubcaps that need clips with the cap fitting inside the center. The later caps fit outside the center ring, fitting over 3 ears that protrude from the center section. FYI, the last set of 15" 6 bolt wheels I bought cost $100.
Fred
52 3600
69 C-10
#189472 09/14/2005 8:14 PM
If you intend to use original hubcaps you will need the second set of wheels posted. The ones with the clips to hold the cap on.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#189473 09/14/2005 8:24 PM
Thanks, guys!
Brian
#189474 09/14/2005 9:48 PM
Yea, i'm not sure i'd pay much more than $25 a piece for those rims.. unless your really having a hard time finding them, or need them right away.
Check local junk yards, mom and pop tire shops, classified section of the local paper, and of course the Stovebolt Swap Meet section periodically.. they always seem to pop up at any or all those places with some frequency.
#189475 09/14/2005 10:24 PM
Fumblin,
Unfortunately in high density areas like I live (Chicago), old stuff is impossible to find. Junk yards don't have anything older than about '80, and tire shops won't sell you anything (if they've kept them) because they're scared of liability.
Brian
#189476 09/15/2005 3:43 AM
I saw about half a bed full of them tonight. But the guy does not ship. You might try RJ in the parts for sale column.
Fred
52 3600
69 C-10
#189477 09/15/2005 4:22 AM
1 Offline
hey brian its nice to see someone else out there with a 60 1/2 ton
#189478 09/15/2005 3:10 PM
Quote
Originally posted by Brian McGee:
Fumblin,
Brian
You may consider expanding your search a bit in your area.. Rockford, Rosco, S. Beloit.. places like that. I'll bet you could find a set cheap less than 2 hours out.. but then you'd have the drive time, etc.
If you can't find them locally, don't have the time to go get 'em, and have the bucks to just nab 'em off eBay at a premium price, then by all means snag those.
I have seen 'em sell cheaper on eBay, tho.
