1 members (FishinToms53),
74
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 158 | I want to use the original hubcaps for my '60 1/2 ton. Having never seen one, though, and not having any of the original wheels, I don't know if these are the right wheels or not. Can someone help me? Auction link [img] http://i21.ebayimg.com/01/i/04/d0/e4/76_1_b.JPG[/img] | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I'm not for sure what sort of hubcaps a '60 uses.. but the earlier trucks (like the '46 thru early 50's trucks) need those little "square root" looking tabs on them for the hubcaps to clip on to.
If your caps just cover the lugnut area, then you probably need to have those "square root" tabs, too.
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | They should work, but the 60 has the hubcaps that need clips with the cap fitting inside the center. The later caps fit outside the center ring, fitting over 3 ears that protrude from the center section. FYI, the last set of 15" 6 bolt wheels I bought cost $100.
Fred 52 3600 69 C-10
| | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | If you intend to use original hubcaps you will need the second set of wheels posted. The ones with the clips to hold the cap on.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Apr 2004 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 158 | | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Yea, i'm not sure i'd pay much more than $25 a piece for those rims.. unless your really having a hard time finding them, or need them right away.
Check local junk yards, mom and pop tire shops, classified section of the local paper, and of course the Stovebolt Swap Meet section periodically.. they always seem to pop up at any or all those places with some frequency.
| | | | | Joined: Apr 2004 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 158 | Fumblin,
Unfortunately in high density areas like I live (Chicago), old stuff is impossible to find. Junk yards don't have anything older than about '80, and tire shops won't sell you anything (if they've kept them) because they're scared of liability.
Brian | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I saw about half a bed full of them tonight. But the guy does not ship. You might try RJ in the parts for sale column.
| | | | | Joined: Apr 2005 Posts: 8 Member | | Member Joined: Apr 2005 Posts: 8 | hey brian its nice to see someone else out there with a 60 1/2 ton | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Originally posted by Brian McGee: Fumblin,
Brian You may consider expanding your search a bit in your area.. Rockford, Rosco, S. Beloit.. places like that. I'll bet you could find a set cheap less than 2 hours out.. but then you'd have the drive time, etc. If you can't find them locally, don't have the time to go get 'em, and have the bucks to just nab 'em off eBay at a premium price, then by all means snag those. I have seen 'em sell cheaper on eBay, tho.
