Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 64 guests, and 3 robots.
Topics128,009
Posts1,055,293
Members48,419
#189403 09/13/2005 4:53 PM
I
I Offline
Block Serial#: 030975IT56X
Block Casting#: 3837004 GM5
Head Casting#: 3836848 GM7
I have figured out that it is a '56 235.
Is this a truck engine or a car engine?
Would it have solid or hydraulic lifters?
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#189404 09/13/2005 5:43 PM
I have the same block #. Inline says '55-'57 235-261. I'm assuming it is a truck engine. While not original, (I have a 3/4 ton GMC) my truck had been used as a tow truck & needed a lot of low end torque. I'm still trying to get more info out of one of the P.O.'s.
#189405 09/13/2005 6:51 PM
I
I Offline
I thought the serial# was the identifier between truck and car...
The block and head casting #'s are for 1956, but I don't know how to decipher the serial#
Inky,
'48 1-1/2 ton Dump
'57 Chevy Panel
#189406 09/14/2005 12:52 AM
X
X Offline
The serial number decodes as follows:
0309751=production sequence number
T=Tonawanda engine plant
56=model year
X=regular production "Thriftmaster" 235 used in the 3100 series trucks.
A truck engine should have solid lifters.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#189407 09/14/2005 11:48 AM
I
I Offline
Thanks Curt!
I knew you would have the answer.
Inky,
'48 1-1/2 ton Dump
'57 Chevy Panel
