| | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Block Serial#: 030975IT56X
Block Casting#: 3837004 GM5
Head Casting#: 3836848 GM7
I have figured out that it is a '56 235.
Is this a truck engine or a car engine?
Would it have solid or hydraulic lifters? | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | I have the same block #. Inline says '55-'57 235-261. I'm assuming it is a truck engine. While not original, (I have a 3/4 ton GMC) my truck had been used as a tow truck & needed a lot of low end torque. I'm still trying to get more info out of one of the P.O.'s. | | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | I thought the serial# was the identifier between truck and car...
The block and head casting #'s are for 1956, but I don't know how to decipher the serial#
Thanks | | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | The serial number decodes as follows:
0309751=production sequence number T=Tonawanda engine plant 56=model year X=regular production "Thriftmaster" 235 used in the 3100 series trucks.
A truck engine should have solid lifters.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Thanks Curt!
I knew you would have the answer. | | |
