8 members (msmall, 68ironhead, Shardean, DannyW, Eisenholtz, 3800GUY, Shade Baby, cmayna),
41
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Well, even though it's 90o here in the Boston area, I suspect that winter will arrive at some point... at least that's the word on the street.
This will be my first snow season with my Bolt. Any suggestions??? Did you add any weight in the bed?? Put snowtires on?? Studs?? | | | | | Joined: Dec 2003 Posts: 103 Member | | Member Joined: Dec 2003 Posts: 103 | I lived in Nashua, NH and worked in Billerica, MA for 9 years. If memory serves me right, I'm not sure that studded tires were allowed. I found that 150-200# of weight above the rear axle worked just fine. Really depends on how stiff/soft your suspension is. Of course a good set of snow tires is a must. | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Studs are allowed, I believe Nov - Apr | | | | | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | If they salt the roads there, buy a winter beater and garage the 'bolt. Otherwise its days will be numbered.
Don't lose your head to save a minute, You need your head, your brains are in it. Burma-Shave (1947)
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | for years i didn't drive my 54-3100/235 because i feared getting stuck. i have 235/70/15 tires and they didn't seem to get much traction. i put about 300# of weight in the back and got around all last winter just fine. i even drove from my shop garage in the back of the house, about 160 ft., to the front, on grass and no problem. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Weight seems to be the magic formula.
Brad, I agree that the east is tough on all vehicles. My Bolt is a daily driver so she'll be seeing winters by necessity... course if I had a ton of money then I'd consider alternatives. | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | Avoid driving on sloppy winter roads, and wash the truck whenever weather permits. When washing it, concentrate on the rust prone areas. Otherwise it will get like this one. http://www.stovebolt.com/gallery/ducor_doug_1966_01.htm | | | | | Joined: Aug 2005 Posts: 60 Member | | Member Joined: Aug 2005 Posts: 60 | Glad I dont have to worry about that stuff here in SoCal.  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | why worry? restore'em once, restore'em twice, restore'em 3 times that's the good part about these simple ol trucks - easy to take apart and fix what needs fixin, and minimal care will increase the time between major rebuilds, plus a bit of attention to rust proofing will prevent the rot problems the poorly finished originals suffered Larry - weight is the key, and if you really wanna get around in the sloppy stuff, try a panel truck w/ mud and snow treads - the weight distribution is better than the pu Bill | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Check out the picture of my "other 48 Loadmaster" in my signature. It was purposely built for winter. It has a V-8 to push an eight foot plow and to pull 4 ton of gravel. Never has been stuck in the snow yet. It's weight caused some problems on sheet ice though, Scott | | | | | Joined: Aug 2005 Posts: 60 Member | | Member Joined: Aug 2005 Posts: 60 | Well, at present I dont have the money for all that re-restoring, I'm just geting started on my first(wish me luck). Nice snow plow 48. Nolan | | |
