| | | Forums66 Topics128,180 Posts1,057,150 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 63 Member | | Member Joined: Aug 2005 Posts: 63 | Hey, new to the page, looking for some help. I just got a 65 1/2 ton (1/4 ton?) stepside with a 250-6 and 4-speed and 4.10 rearend. A BIT low geared for my tastes... actually, a lot low geared for my taste. Anyone have any info on what ratio in the rear I should go to for some speed / mileage? Now, I'm running 2,400 rpm at 50 mph. I'd LIKE to be running 2,400 rpm at 65 mph. Surely someone else out there has done all this. HELP! Thanks! randy | | | | | Joined: Feb 2000 Posts: 5,236 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,236 | I am running a 250 and turbo 350 automatic with a 3.08 gear. 70 mph at 2400 2500 rpm. Truck weight is around 3400lbs. You should be able to get by with a 3.55 or 3.73 pretty easy. Joe | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | 3.73 was the standard rear for these trucks, should be an easy find. Brian | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | A guy told me once he preferred to put hamburger in his rearend instead of grease.. sounded like a good way to attract flies.
| | | | | Joined: Aug 2005 Posts: 63 Member | | Member Joined: Aug 2005 Posts: 63 | Hamburger... hmmmmm... I think he told you he had put a hamburger in between some BUNS! Obviously there was some confusion! (...and undoubtedly some embarassment at HIS barbeque I might add!!!). Fumblin', how close are you to Chadron? | | | | | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | is this an attempt to quiet down the rear end or is it normal to use grease in the pumpkin? mine has 90w in it.
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Originally posted by old_blue: is this an attempt to quiet down the rear end or is it normal to use grease in the pumpkin? mine has 90w in it. So does mine. | | | | | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | i've heard of sawdust in the rear end to make it tighter and quieter, but hadn't heard of grease. someone who knows better than i, could you please let us know of a valid reason for using grease in the rear diff cause i'd sure be interested to know? and, does it work? i know it wouldn't work in the tranny cause of the bearings. not sure if it's a good idea in the rear end though. thanks
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I think Randy was just referring to 'feels like' for a post title, if you read his question best I heard of was oatmeal to quieten gears down ,,,, just before the prospective purchaser comes for a test drive! Bill | | | | | Joined: Aug 2005 Posts: 15 Junior Member | | Junior Member Joined: Aug 2005 Posts: 15 | Nope, not generally a good idea to put grease in the differential. Although I've taken some apart that the oil had turned to grease--burnt grease at that! One of the reasons it doesn't work is that the gear lube also needs to cool the gears--which is another function of both engine oil and transmission oil/fluid. Grease doesn't allow the gears and other parts inside the diff the chance to cool down as it moves around. | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | the grease will plug up the seals if leaking we used to do it with outboard motors to seal up lower ends and to keep the water out | | | | | Joined: Aug 2005 Posts: 63 Member | | Member Joined: Aug 2005 Posts: 63 | Hey, thanks everyone! No, I don't REALLY have grease in my rearend (that was just a quip to get attention, sorry for the mis-direction there!) You've been a help and now I'll be searching every old chevy / gmc trailer and doner truck to find a 3.08 or 3.55 third member for my '65. I've heard from a friend that if my search is fruitless, I have options of installing a ring and pinion, or that there's a kit available to install a newer rearend, but I know that the 'set up fee' for those are costly, so for now, I'll just have to drive slower when I'm heading out to my favorite huntin' spot... | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | google up http://www.smokemup.com/auto_math/index.php go to gearing and plug in your details. if you are planning on a different differential check this site. keep in mind if you change trannys your overall speed will too. gooday jim
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jul 2005 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 117 | Not that I'd ever use it in a high speed gearbox like a trans or rear axle but, cornhead grease works great in a manual steering gearbox. The grease has the thickness of honey and is less likely to run past a leaky seal. The steering gears work like silk if the bearings and bushings are good. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If this is a 1/2 ton (six lug), there are definately 3.08 gears available for it. I've got a 3.08 rearend out of a half ton sitting in my garage waiting to go into my '50. You can just change the ring and pinion in these, but the gears will need to be re-shimmed. They are out there, I got mine for $100. Keep looking.
