2 members (Woodcmiami, baldeagle), 93 guests, and 10 robots.
Topics128,014
Posts1,055,324
Members48,419
#187918 08/18/2005 4:25 AM
Junior Member
Junior Member
i seem to have a huge oil leak..im thinking it is the gaskets...any other thoughts? and if i can get gaskets..how much would they cost and where can i get them locally? (idaho, 1935 chevy) :confused:
#187919 08/18/2005 10:56 AM
Where does the oil look like it's coming from? My first instinct would be to replace the valve cover gasket;that's about the only gasket surface that gets disturbed via service on the old stovebolts.
Does it leak more when you drive it,or when it's parked? Or is as bad either way?
Other possibilities would be: lifter cover,timing gear cover,harmonic balancer seal,rear main,oil filter lines or canister (if you have a filter on your engine),fuel pump gasket.
Gaskets shouldn't cost much,and there's a lot of places that will have what you need.I doubt there's a gasket or seal in your engine that'd be more than 15 or 20 dollars.You might check some of the vendors you see referenced on this website for your parts.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#187920 08/19/2005 2:19 AM
Junior Member
Junior Member
It leaks bad when driving..and shortly afterwords. It is leaking from the valve cover gasket....tks alot speed
#187921 08/19/2005 2:28 AM
Try your local auto parts store, believe it or not, many parts for these old trucks are still available from them.
#187922 08/19/2005 3:38 AM
Autozone actually had all 3 gaskets for my '56 235 cid, 21 bux-ish for the set.
artificial intelligence will never overcome natural stupidity
