| | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6 Junior Member | | Junior Member Joined: Aug 2005 Posts: 6 | i seem to have a huge oil leak..im thinking it is the gaskets...any other thoughts? and if i can get gaskets..how much would they cost and where can i get them locally? (idaho, 1935 chevy) :confused: | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Where does the oil look like it's coming from? My first instinct would be to replace the valve cover gasket;that's about the only gasket surface that gets disturbed via service on the old stovebolts. Does it leak more when you drive it,or when it's parked? Or is as bad either way? Other possibilities would be: lifter cover,timing gear cover,harmonic balancer seal,rear main,oil filter lines or canister (if you have a filter on your engine),fuel pump gasket. Gaskets shouldn't cost much,and there's a lot of places that will have what you need.I doubt there's a gasket or seal in your engine that'd be more than 15 or 20 dollars.You might check some of the vendors you see referenced on this website for your parts. Speed | | | | | Joined: Aug 2005 Posts: 6 Junior Member | | Junior Member Joined: Aug 2005 Posts: 6 | It leaks bad when driving..and shortly afterwords. It is leaking from the valve cover gasket....tks alot speed | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Try your local auto parts store, believe it or not, many parts for these old trucks are still available from them. | | | | | Joined: Feb 2004 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 36 | Autozone actually had all 3 gaskets for my '56 235 cid, 21 bux-ish for the set.
artificial intelligence will never overcome natural stupidity
