0 members (), 74 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#187448 08/13/2005 6:56 PM
Apprentice
Apprentice
Hi everyone,
I need to remove my tailgate (its a 54) and put on a new one with new hinges, chains, etc. How to get the old one off? I thought about cutting the bolts with a sawsall, but that will undoubtedly damage the body. the hinge just turns and turns, bolt rusted pretty good.
#187449 08/13/2005 7:47 PM
I can't remember exactly how that goes together, but have you thought of drilling the head and shaft off? Or, could you squeeze the hinge trunion inside the tailgate with a great-big-huge pair of vice-grips to help get some torque on the bolt?
#187450 08/13/2005 8:27 PM
HorVath has a very good posting on that subject here on this site. I think there are holes in the bottom of the tailgate that you stab something through to keep trunion from turning as you remove the bolts.
#187451 08/14/2005 1:25 AM
Insomniac
Insomniac
There is a slot in the trunion that you can insert a screwdriver in to stop it from turning. I twisted the bolts off on both sides getting the tailgate off, so I need new trunions and bolts. Use lots of WD40 and hope for the best.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
#187452 08/14/2005 4:10 AM
I had a bit of an ordeal figuring out how to remove mine, but I got lucky:
Read This
I hope that helps.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#187453 08/15/2005 1:55 PM
Gord is right. Spray the whole thing with WD 40. Then, slip a screwdriver into the slot on the trunion and use a breaker bar to turn the bolt. Should twist right out. I replaced the bolt and trunion before replacing the repainted tailgate.
~ Kimberly
My '54 ... and my '63 and a '59 F100
#187454 08/15/2005 2:31 PM
Junior Member
Junior Member
No you are all wrong, you send a 10 yr old child out there to "play" and with any luck the next time you go to take the bolts off they will already be removed and it will tumble off when a slight breeze hits it. Thats what happened to my Dad when he went to take his off! What a shocked look on his face! He struggled with those old rusty bolts for days-spraying everything he could find on them, took the top ones off and wham a trip to the hospital with two broken toes. I guess my sister thought she would help! The moral of this story: Don't ever rant and rave around your kids about your stuck tailgate-you may get what you wish for!
Lori
#187455 08/16/2005 9:00 AM
Apprentice
Apprentice
Wow, thanks everyone for the tips, I knew there must be a trick to it. Alan, the pics helped. Thats a beautiful 54 , Kimberly . One day I'll paint mine like, ONE color.... G man.
