8 members (3B, cshades, cmayna, Gdads51, moparguy, MickeyP, JW51, 1 invisible),
104
Mod | | | Forums66 Topics128,064 Posts1,055,861 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | i've totally removed the screw inside the window crank and tried prying and tapping it with a hammer but i can't get it off. is there a pin, ring or something else i need to remove to get this crank off my 53 gmc? thanks
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what year? the type w/ the set screw don't have any other keeper unless some PO added something, which you should be able to see - should be able to pry under both sides at once and get it, just be careful of bending the panel behind it
try rolling the window all the way up and see if the crank can be forced [gently] further, then go all the way down and repeat - if the gnurling in the handle or on the shaft is messed up it's prolly just snagged and you might get it to shift a bit and loosen
Bill | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | My 62 just has a set screw and it pulls right off. You may have a bit of rust holding it on. Yank that sucker!
delete my account and pictures
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | When I pulled mine I took out the set screw but the handle would not fall off. So I took my pry bar and tried ending with a resounding crack. Seems someone drilled a hole thru the handle boss and the knurled shaft and put a nail thru the hole. The nail didn't break but the knurled end split and I was in trouble. Luckily I found another regulator and pulled the knurled shaft and pop riveted it in place. Yes the rivets are strong enough in the shear. The window regulator mechanisms vary from 1950 it seems. Teeth and such. | | | | | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | thanks guys, that's what i thought too, but it won't come off. i don't wanna break it but i might have to. appreciate the replies. tony
| | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Mine had a set screw on top of another smaller set screw. Took the first one off and looked real close and saw another one down deep. It must of kept loosening and the PO tapped another screw in to back it up. May want to check it out. | | | | | Joined: Jun 2005 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 37 | Like shipwright said, check to make sure there isn't another set screw below the first one. If not, with the set screw removed, spray WD-40 or some other rust remover down the set screw hole and wait about 10 minutes and try to evenly apply pressure on both sides while trying to remove the handle. If all else fails remember this, a window regulator goes for about $75.00 new, whereas a window handle runs about $7.00. So be careful not to mess up the regulator. I once had to get two pieces of 1/4 plywood about a foot long, paper towels and two long screw drivers and laid the paper towels across the door panel to protect it, then the plywood over the towels across the door panel vertically, then sliding the long screw drivers between the plywood and window handle on both sides at the same time to remove a stubborn handle. Worked for me, good luck. | | | | | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | Not sure about trucks but the 40s/50s pasenger cars have omega shaped clips that come of easy with a special tool. [img] http://www.eastwood.com/images/us/local/products/detail/p537.jpg[/img] It can be done with two verry small screw drivers but it is a pain in the A...! It is almost impossible to remove the crank/handle with the clip on unless you ruin something (blood/sweat /tears - Job) Check chevs of the 40s for the right tool for your year. It is only a view $ and worth every cent. Frank | | |
