4 members (78buckshot, klhansen, 2 invisible),
147
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Still trying to figure out the cheapest, best way to lower my C20. This idea was brought up to me and thought I'd run it by y'all. Cut out the existing coil spring mount on lower control arm, the pocket where the spring sits. Fabricate new mount/spring pocket but approximately 2" lower resulting in 3-4" drop. This way, original springs could be retained and not affect the ride. Here's a picure: lower control arm fab. I love fabrication so this is right up my alley. The rear bags will be bolt-in, boo hiss!  Can anyone think of any adverse effects I may incur doing this? -David | | | | | Joined: Feb 2005 Posts: 81 Member | | Member Joined: Feb 2005 Posts: 81 | the ride will still be affected, as the suspension geometry changes just as if you'd cut the springs. what you do gain is no change in spring rate, i suspect that is what you mean. just make sure your bump stops are doing their job correctly after the drop.
lowering spindles or Zing the frame are the only ways i know of around that. i'm no expert though, i had cut springs on a 63 lincoln at one time. if i had the resources i'd have done what you're considering. go for it | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Yeah, spring rate stays same. That's gotta be better than cutting coils I'd think. -David | | | | | Joined: Jul 2005 Posts: 15 Junior Member | | Junior Member Joined: Jul 2005 Posts: 15 | Check Moroso, they have an a-arm fab kit that you could mod. Competition Engineering has some trick pices that may help as well. | | | | | Joined: Jul 2005 Posts: 15 Junior Member | | Junior Member Joined: Jul 2005 Posts: 15 | Sorry not Moroso, Competition Engineering. Part #C2450 or C2451 with a nice coil over shock or air bag. Oh you said cheap didnt you. | | | | | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | that would work, but i would just cut the spring.
make sure you get shorter bumpstops, and shorter shocks.
2003 ford lightning 1959 chevy 36
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | If you go w/2inch lower spring the ride is not too bad, a little over $100 from CPP or ECE. I have them in front of my 64. I cut about an inch off of the bumpstop. Brian | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | early classic makes a half ton conversion drop spindle in case you want to go with five lugs. | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Yep, yep. Cheap. I can get the pipe for free. The only thing that'll cost me is welding wire and a couple cans of paint. I'll be changing out the ball joints at the same time but, they need done anyway. Why cut coils if I don't have to? Yeah, this'll take a bit longer than cutting coils but I keep the same spring rate, right? Well, nobody's mentioned any possible adverse affects. That's good. I'm taking two weeks off in September. That's when this is gonna happen. Thanks for the input thus far. -David | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | You will still have 40 year old springs, I noticed a big improvement when I replaced mine. Brian | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | let me sit in it, I can lower it real quick, would be a real cheap deal  Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Well, maybe the best bet is to lower it 2" with the fabrication and then install new 2" drop springs. Fred, so you're sayin' your wife's a good cook huh? -David | | | | | Joined: Feb 2000 Posts: 5,210 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,210 | It should work OK, the most it might do is throw off the camber a little. Head to the aligment shop when you get it on the road just for peace of mind! Joe | | | | | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | It will work great BUT make sure whoever does the welding knows what hes doing and a good alignment shop will be the next step. | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | I know the guy who's gonna do all the fabrication and welding. A very capable fellow indeed. Goes by "mugsy". Ya heard of him? -David | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Have seen a similar idea on a VERY different application: My Austin-Healey Sprite parts book has lowering kits that do just that. The spring pocket on the sprite/midget are bolted to the control arms, so they make longer bolts and spacers to lower the front end about 1/2 to 1". There is no mention of adverse geometry.
Good Luck
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
