Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Hotrod Lincoln, UtahYork, 66flea), 163 guests, and 3 robots.
Topics128,284
Posts1,058,523
Members48,490
Still trying to figure out the cheapest, best way to lower my C20. This idea was brought up to me and thought I'd run it by y'all. Cut out the existing coil spring mount on lower control arm, the pocket where the spring sits. Fabricate new mount/spring pocket but approximately 2" lower resulting in 3-4" drop. This way, original springs could be retained and not affect the ride. Here's a picure: lower control arm fab.
I love fabrication so this is right up my alley. The rear bags will be bolt-in, boo hiss! grin Can anyone think of any adverse effects I may incur doing this?
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
the ride will still be affected, as the suspension geometry changes just as if you'd cut the springs. what you do gain is no change in spring rate, i suspect that is what you mean. just make sure your bump stops are doing their job correctly after the drop.
lowering spindles or Zing the frame are the only ways i know of around that. i'm no expert though, i had cut springs on a 63 lincoln at one time. if i had the resources i'd have done what you're considering. go for it
Yeah, spring rate stays same. That's gotta be better than cutting coils I'd think.
-David
My \'65 Chevy C-20
Junior Member
Junior Member
Check Moroso, they have an a-arm fab kit that you could mod. Competition Engineering has some trick pices that may help as well.
Junior Member
Junior Member
Sorry not Moroso, Competition Engineering. Part #C2450 or C2451 with a nice coil over shock or air bag. Oh you said cheap didnt you.
1 Offline
that would work, but i would just cut the spring.
make sure you get shorter bumpstops, and shorter shocks.
2003 ford lightning
1959 chevy 36
If you go w/2inch lower spring the ride is not too bad, a little over $100 from CPP or ECE. I have them in front of my 64. I cut about an inch off of the bumpstop. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Z
Z Offline
early classic makes a half ton conversion drop spindle in case you want to go with five lugs.
Yep, yep. Cheap. I can get the pipe for free. The only thing that'll cost me is welding wire and a couple cans of paint. I'll be changing out the ball joints at the same time but, they need done anyway.
Why cut coils if I don't have to? Yeah, this'll take a bit longer than cutting coils but I keep the same spring rate, right?
Well, nobody's mentioned any possible adverse affects. That's good.
I'm taking two weeks off in September. That's when this is gonna happen.
Thanks for the input thus far.
-David
My \'65 Chevy C-20
You will still have 40 year old springs, I noticed a big improvement when I replaced mine. Brian
let me sit in it, I can lower it real quick, would be a real cheap deal grin
Redryder pix
My Hotrod
Well, maybe the best bet is to lower it 2" with the fabrication and then install new 2" drop springs.
Fred, so you're sayin' your wife's a good cook huh? wink
-David
My \'65 Chevy C-20
It should work OK, the most it might do is throw off the camber a little. Head to the aligment shop when you get it on the road just for peace of mind! Joe
V
V Offline
It will work great BUT make sure whoever does the welding knows what hes doing and a good alignment shop will be the next step.
I know the guy who's gonna do all the fabrication and welding. A very capable fellow indeed. Goes by "mugsy". Ya heard of him? wink
-David
My \'65 Chevy C-20
Have seen a similar idea on a VERY different application: My Austin-Healey Sprite parts book has lowering kits that do just that. The spring pocket on the sprite/midget are bolted to the control arms, so they make longer bolts and spacers to lower the front end about 1/2 to 1". There is no mention of adverse geometry.
Good Luck
