1 members (59 fleet), 62 guests, and 9 robots.
Topics128,021
Posts1,055,353
Members48,420
#185285 07/11/2005 7:03 PM
Junior Member
Junior Member
My e-brake cables are frozen in their housings at the back of my 62 Chevy. What are the chances of an oil soak getting them free? Who supplies replacements? All I've found are 63 and up replacement cables. Are there good aftermarket setups that replace everything? Thanks.
Priorities make dreams happen.
#185286 07/11/2005 8:56 PM
Stephen, I just got mine from Chevy Duty.
Brian
#185287 07/11/2005 9:15 PM
Personally I'd replace the cables. Obviously they're corroded hence the seizure, and you certainly don't want one failing!
I too would suggest Chevy Duty; used them for the first time last week and was SERIOUSLY well impressed by the speed of service.
63 GMC Fleetside; overbuilt, over-thirsty and over here!
#185288 07/12/2005 3:39 AM
Try Carquest or NAPA first, I still get parts for my 48 1 1/2 ton through Carquest,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#185289 07/12/2005 7:48 AM
Stephen,
Dump the rusty cables. You will be glad you did. I second the Car Quest route. I live a couple of miles from the regional depot...they have had many of the parts I need.
#185290 07/12/2005 1:25 PM
Junior Member
Junior Member
Can I put the brakes back together with out the parking brake cable and drive around? My truck has been on blocks for a couple of days and those around me aren't very happy. Thanks, the chevy duty price wasn't too bad.
#185291 07/12/2005 2:20 PM
Stephen,
If you remove the cable, the lever, the c-clip, and the parking brake return lever and spring (the horizontal bar in the brakes) you should be able to run just fine. At that point you'll notice your back brakes look EXACTLY like your front!
Brian
#185292 07/12/2005 7:48 PM
yes Stephen, you sure can drive without the emergency brakes working, but, if your truck is like mine with a single reservoir master cylinder, i like having those parking/emergency brakes; just in case. :-)
tony
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
#185293 07/12/2005 7:51 PM
NAPA, etc. couldn't get the correct ones for my 64(too long/short/wrong end), had to go w/Chevy duty, fit good although it was a plastic covered cable unlike the OE. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#185294 07/13/2005 3:47 AM
Junior Member
Junior Member
I got new cables from a classic parts dealer that I found in the phone book. $35 per side. Their website is http://www.hhclassic.com
