7 members (Hotrod Lincoln, dt235sd, MickeyP, 32Fordpuchoptop, Peggy M, 2 invisible), 84 guests, and 1 robot.
Topics128,033
Posts1,055,531
Members48,425
#184861 07/05/2005 3:35 PM
Where did the name 3100 come from? What does it signify? A quick answer would be greatly appreciated, as I am trying to end a heated office discussion. Thanks!!
~Joe
'57 Chevy 210 (235)
'54 Chevy 3800
'49 Pontiac Streamliner (239)
'46 Chevy 3/4-Ton (216) (Sold)
'46 Chevy 1 1/2-Ton (Sold)
'50 Chevy Loadmaster Semi (Sold)
'68 Chevy Stepside (Sold)
#184862 07/05/2005 3:49 PM
if you mean why did they use those particular numbers - cuz the engineer committee met w/ the marketing committee and the management committee, and the production committee, and they drank too much coffee, and close to quiting time said HAY! quick! gimme a number!
if you mean where's the meaning - the numbering scheme was a replacement for the previous letter designations, which were getting cumbersome and confusing - 3100 is the "generic" designation for 1/2T short truck, then the last numbers pinpoint the 'style' -> 04 = pu
beyond that the 3200 series = long frame, 3600= 3/4T, 3800=1T and such
#184863 07/05/2005 5:22 PM
As far as I can tell, they came out of the marketing department's @$$.
1954 GMC De Luxe COE
#184864 07/05/2005 6:21 PM
See, now I figured they came the other direction. I thought the engineering department just came up with arbitrary model designations (like 14 for 1/2 ton SWB and 15 for 1/2 ton LWB giving you the 1500 series pickups of later years), and the marketing latched onto it.
This seems to make more sense than the rectal extraction.
Brian
#184865 07/06/2005 1:35 AM
Brian. Maybe. Never underestimate what marketing can pull out of their backsides.
It would make sense if they were engineering designations, though.
