1 members (stlcardinalsguy),
71
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 79 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 79 | Where did the name 3100 come from? What does it signify? A quick answer would be greatly appreciated, as I am trying to end a heated office discussion. Thanks!!
~Joe | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you mean why did they use those particular numbers - cuz the engineer committee met w/ the marketing committee and the management committee, and the production committee, and they drank too much coffee, and close to quiting time said HAY! quick! gimme a number!
if you mean where's the meaning - the numbering scheme was a replacement for the previous letter designations, which were getting cumbersome and confusing - 3100 is the "generic" designation for 1/2T short truck, then the last numbers pinpoint the 'style' -> 04 = pu beyond that the 3200 series = long frame, 3600= 3/4T, 3800=1T and such
Bill | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | As far as I can tell, they came out of the marketing department's @$$. | | | | | Joined: Apr 2004 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 158 | See, now I figured they came the other direction. I thought the engineering department just came up with arbitrary model designations (like 14 for 1/2 ton SWB and 15 for 1/2 ton LWB giving you the 1500 series pickups of later years), and the marketing latched onto it.
This seems to make more sense than the rectal extraction.
Brian | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Brian. Maybe. Never underestimate what marketing can pull out of their backsides.
It would make sense if they were engineering designations, though. | | |
