8 members (Bill Hanlon, 52Carl, Danielbolt, Hotrod Lincoln, NJC, Stovebolt48, Gdads51, 1 invisible),
46
Mod | | | Forums66 Topics128,180 Posts1,057,163 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 75 Member | | Member Joined: Mar 2005 Posts: 75 | Has any one used the under bed tank from LMC or classic trucks, 20 gallon with sending unit. so far I cut the spare tire brace out of the way and tried to line up the tank with holes in the frame and it looks like the bed cross membewr is in the way and the fill pipe runs into the frame. the ring on the tank is about two inches below the frame and the j bolts that came with the tank are to short are am I doing something wrong. Does any one have picture of this tank installed? Got to get the tank under the bed soon that gallon gas under the hood does not last very long and is not safe. How do you mount it? Were do the straps go and how did you attach them to the frame? :confused: | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | For the kind of bucks they get for those tanks, you'd think they'd include some kind of instructions!
Thank god for The Stovebolt Page, tho.. i'm sure someone else whos installed one will be along to help.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i didn't use that particular one and i have a 54/3100. the one i got the crossmember had to be removed and the frame c-notched. which raises the tank then maybe your u bots will reach. i had to remove my bed to do this. hope this helps. RON
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Mar 2005 Posts: 75 Member | | Member Joined: Mar 2005 Posts: 75 | Well no one else has put a under bed gas tank i from this supplier? | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Super, I didn't know they sold an under bed tank for old bolts or your 63 C10. when I just looked online at their catalogs they all show cab tanks. where did you get /or what year catalog did you use?
Fumblin' 46, some of these vendors just don't get it, quality and service is what we always want
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I'm in the proccess of installing my LMC tank now. I've got the tank in and I'm getting ready to plumb it soon. I just welded a couple of square tubes across to each frame rail to form a box, clamped the tank to it, bent the straps to follow the contour of the tank, drilled and tapped the frame (which is double thickness and boxed back there) and bolted the straps up. I used stainless steel hardware so I didn't use the J-bolts. If you what, I can take a few pictures if you like, my truck is just a rolling chassis right now, Scott | | | | | Joined: Mar 2005 Posts: 75 Member | | Member Joined: Mar 2005 Posts: 75 | Scott would like to see some pictures. What year truck are you putting that on? Carolines Truck the catlog is number CBE.19 spring 2005 1960-66 LMC the last time I looked it was not on the online site only in the book.
Super250six | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | My truck is a 63 3/4 ton 4x4, but the frame area back there should be similar to yours. I'll run out and snap a few pictures for you. Scott | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | | | | | | Joined: Mar 2005 Posts: 75 Member | | Member Joined: Mar 2005 Posts: 75 | Scott how tall is the frame in the back by your tank? when I put my tank up there as far as it will go there is about a two inch gap from the tank flange to the frame. The filler neck end up in the middle of the frame. Thanks for the pictures that will help me on were I needed to put the tank. what size lines are you going to run up to yopur motor? I think I am going to run 3/8 steel line to the fuel pump and also put a electric pump at the tank. Thanks Super250six | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | My frame is about 5 inches thick from the back forward until it starts to bend for the axle. Did your get the steel tank kit or the plastic tank? If you got the steel tank, the fill neck looks like it will unbolt from the tank. You could get one custom bent to clear your frame, I would think, but mine looks like it's in the perfect position. I bought 3/8 steel fuel line that came in a 25' roll so I'll have no splices from tank to pump. Do you have a picture of what's going wrong with your tank? Also, my tank had some "tabs" sticking up through the flange that I ground flush. These holes seemed to be where the bolts for the straps needed to go, don't know why they did it that way. I had to enlarge the holes some to get 3/8 bolt through them. Good luck and let me know if I can be of any help, Scott | | | | | Joined: Mar 2005 Posts: 75 Member | | Member Joined: Mar 2005 Posts: 75 | Scott I got the steel tank and the filler is welded to the tank. Were did you get the steel line in a 25 foot roll so far all I find here is 5 foot pices.
Super250six | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Barron Motor Supply in Cedar Rapids, Iowa. Not sure who the vendor is but it's pretty heavy duty stuff. It bent my cheapy tubing bender. It has a copper colored inner liner and a galvanized look on the outside. If I remember, I'll call them tomorrow and see where it comes from, Scott | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Hey Super, The fuel line is made by AGS and is sold by Pronto if any of that helps you, Scott | | | | | Joined: Mar 2005 Posts: 17 Apprentice | | Apprentice Joined: Mar 2005 Posts: 17 | I just feel really sorry for the guy that owns an 85 dodge Caravan and a PP cruiser.
1bad58
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | 1bad58, WHY????????????????
