0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#184720 07/02/2005 3:31 PM
I
I Offline
The oldest son and I were working on stripping some parts off of the donor Blazer yesterday.
We also have a donor Chevy van. It is a IRWIPI 12 years ago - freebie that I figured we might get something useful out of so we towed it home. I was curious as to whether or not it would actually run, so I hooked up a set of jumper cables, poured a little gas in the carb and cranked it over.
Wouldn't you know it, it sparked to life. It sat there running on 12 year old gasoline for about fifteen minutes, then I threw it into reverse and it actually moved, so I put it in drive and it moves forward as well. I am totally amazed!... I didn't even lube the cylinders first!
We might end up using the tranny for the 57 Panel, and the engine will probably end up in the swap meet eventually. (its a six cylinder...250?...I think)
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#184721 07/02/2005 5:45 PM
you caught her in just the right mood,,,,,,,,,,,Fred
just drive em,,,,,,,,,,,,,,,,,,,,,,,,,,
Redryder pix
My Hotrod
#184722 07/02/2005 6:07 PM
I
I Offline
Guess you're right, Fred. I don't usually get that lucky wink
Inky,
'48 1-1/2 ton Dump
'57 Chevy Panel
#184723 07/02/2005 8:30 PM
Junior Member
Junior Member
Awesome, these old Chevy's are just wanting to show that they just keep going. It was just waiting to show you what she could do.
Owen Miller
#184724 07/03/2005 12:42 AM
You're probably lucky you had 12 year old gas in it. This modern crap goes bad in about 6 months!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
#184725 07/03/2005 7:28 AM
Where can I get some of that good six month stuff? Seems like out here it sours if I don't drive my truck for two weeks...
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#184726 07/03/2005 2:21 PM
I
I Offline
Speed, I might have a couple gallons of the twelve year stuff I could sell you... LOL
If the new stuff is $2.25/Gal. then the aged stuff should be worth $5.50... Right???
Inky,
'48 1-1/2 ton Dump
'57 Chevy Panel
#184727 07/05/2005 10:57 PM
Junior Member
Junior Member
I recently had the same experience with a 1959 Dodge D100. I got it started on the 15+ year old gas. It ran but it was a little lean. I cleaned the carb and it ran better but still lean. I think that the gas had lost most of its volatility. It since ran out of gas and I havent had time to pour fresh stuff in and try again. I do know that todays fuels go varnishy in a few months. I was amazed at the old gas.
