0 members (),
130
Mod | | | Forums66 Topics128,078 Posts1,056,049 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18461 05/04/2004 4:37 PM | Joined: Mar 2004 Posts: 21 Junior Member | | Junior Member Joined: Mar 2004 Posts: 21 | I am sand blasting the rims, painting and buying new tires for my 1951 1-ton dually. It has 18" split rims. The local tire guy says he will investigate but thinks there are only about two options for tread patterns on the 18x700 rims.
Any suggestions on tires, manufactures, prices... would be appreciated. I use the truck for getting wood and hay. Don't really need off-road tires but it is a consideration for Northwest Montana.
Thanks. Randy | | |
#18462 05/04/2004 8:09 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I have to admit I have never seen an 18" truck tire. Go to www.cokertire.com they show one 7.00-18 bias ply truck tire.
Fred 52 3600 69 C-10
#18463 05/04/2004 9:26 PM | Joined: Mar 2004 Posts: 21 Junior Member | | Junior Member Joined: Mar 2004 Posts: 21 | Wow. I am finding that out -- these 18" tires are rare. My local tire guy has called 5 or 6 places and all he finds is one ribbed street tire available. I am more interested in a traction tire.
Anyone have a contact for an 18" traction tread type tire? | | |
#18464 05/05/2004 6:48 AM | Joined: Nov 2003 Posts: 53 Member | | Member Joined: Nov 2003 Posts: 53 | They may be too big for your truck, but surplus military Gama Goat tires are available. The 'Goat uses 11.00-18 NDT (military lug) 6 ply tires. Try Jack Tomlin in Tooele, Utah at 435-882-0420 or Larry Johnson in Ogden, UT at (801)731-1120. Last I knew they had a large quantity of them from $65 to $90 each. | | |
#18465 05/08/2004 2:11 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I found two ads in Vintage Truck magazine. One is Miller Tire , website is down right now. Also Lucas Automotive in Long Beach, CA. 800-952-4333. Both list 18" tires in their ads, don't know if either has a traction tread.
#18466 05/09/2004 3:31 AM | Joined: Mar 2004 Posts: 21 Junior Member | | Junior Member Joined: Mar 2004 Posts: 21 | Hey, thanks everyone for the leads. I will followup next week and let you know if I found the tires.
And thanks for the lead to to Vintage Truck magazine -- I subscribed and look forward to getting it in the mail.
Randy | | |
#18467 05/09/2004 4:22 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Anyway to convert to a 16" wheel? Then you could go to a radial tire or at least have a wider variety to choose from. Scott | | |
#18468 05/09/2004 4:22 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Vintage Truck is a darn good magazine!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#18469 05/09/2004 2:46 PM | Joined: Mar 2004 Posts: 21 Junior Member | | Junior Member Joined: Mar 2004 Posts: 21 | 48BIGTRUCKS, thanks for your suggestion about converting to 16's - I don't know the answer but it is a consideration. One thing though, I kind of like a larger sized wheel on a 1-ton dually - if its possible. I wonder if going to a 19 or 20 inch might work.
thanks. | | |
