| | | Forums66 Topics128,078 Posts1,056,036 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18419 01/17/2005 3:02 PM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | I want to add a new dual chamber mastercylinder (drum/drum,no booster) to my 50 chevy 3100 w/ original huck brakes. I also want to replace original steel lines. I hear that bending lines can be trickey, so is there a supplier that has ready made, pre-bent lines for my truck?
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | |
#18420 01/17/2005 5:12 PM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | I show 'em in Chevy Duty and LMC Truck catalogs. Any of the major catalogs should have them. Let me know how it works out; brakes are number one for my 47 as soon as my garage thaws
Your lack of preparation is not my emergency
#18421 01/17/2005 5:26 PM | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 |
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
#18422 01/17/2005 8:53 PM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | Where did you find a dual MC without booster? I wasn't sure they made those...
jay
#18423 01/17/2005 11:41 PM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | classicperform.com has them and the adapter that is also needed
Blue 50
#18424 01/18/2005 5:41 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Jay - I just bought a drum dual master cylinder from Master Power Brakes without a booster.  They have them with right and left line connections. Very nice and accommodating folks! www.mpbrakes.com
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#18425 01/18/2005 8:40 AM | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | I see that 6cylindertexas beat me to a link to MPBrakes so I'll add this as seconding his opinion. [img] http://www.mpbrakes.com/mc1004.jpg[/img] Power masters like the one above, usually have very shallow holes in the piston for the rod. As it says, that one is set up for use below the floorboard. Non power masters must have a smaller piston diameter or you will have to use both feet on the pedal. Non power masters usually have a very deep hole so that the rod does not fall out when you take your foot off the pedal and the spring returns the rod faster than the fluid moves the piston back. Here is a page from MP with answers to everything you never thought you needed to know. Master Cylinders
'67 GMC 3/4 292 4spd
#18426 01/18/2005 4:05 PM | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | does anyone know if that one shown from mcbrakes would be a "bolt in" with some mods to the lines? i have a 54 chevy and need to replace the mc and may as well go this way if it doesn't require major mods.
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#18427 01/19/2005 1:02 AM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | djed50, you will need an adapter as the original bolted to the frame and if you look at the bolt holes on the MC you are talking about, it does not bolt to the original location but paralel to the frame on an adapter. classicperform.com has some great installation info and exploded views on this in there tech section. you would also need to run seperate lines to each chamber of the new MC. vwnate1 gave me the idea to get rid of the T junction that splits front/rear lines and get a couple of elbows and then run your own lines to the MC. just picked them up from FLAPS....looks like they will work great.
Blue 50
#18428 01/19/2005 6:36 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | djed50 - Check this out for the adapter you would need. www.chevyduty.com/frame-store.html
#18429 01/19/2005 6:41 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | :confused: OPPS ! Sorry! You need to type in "Master Cylinder Adapter Kit" in the Search box. That's it!
#18430 01/19/2005 7:06 PM | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 |
#18431 01/19/2005 10:56 PM | Joined: Jul 2004 Posts: 18 Apprentice | | Apprentice Joined: Jul 2004 Posts: 18 | I'm a bit late to this thread, but, anyway: After a somewhat unfortunate incident last month involving a load of goad manure, a rusted brake line, and a very steep hill, I've decided to upgrade the system on my '63 daily driver. I immediately replaced all lines, drums, etc., and now its time for the master. I want to go to a dual master. Why would someone opt to not get a power assist? Any reasons other than price? I want to keep the drum/drum layout, go to a dual master, and, basically, have the safest system I can get without rebuilding the whole truck ....
'63 half-ton another '63 half-ton '62 school bus
#18432 01/19/2005 11:03 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Blue 50,
I ordered a pre-bent kit last year...it was OK...but I would try doing it yourself. The kit was expensive. The lines come bent in half in a box....that surprised me....
You need a good bender, flaring tool and patience.....save your old lines..if it is not too late...for a pattern..... | | |
#18433 01/20/2005 1:34 AM | Joined: Nov 2004 Posts: 170 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 170 | Blue, I was asking the same questions just a while back and these guys talked me into doing it myself. It was the right thing to do. You can get a kit from Eastwood Co. to start for around 30 bucks. I did end up going to Napa to get some misc. stuff and an extra line and cut it to the size I needed. Everything that these guys have mentioned is right. Go for it!!! | | |
#18434 01/20/2005 1:56 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | f63 - In my case (I've got a 1937 pickup) and in most cases with a truck up to at least 1955, the master cylinder is under the floorboard and fitting a booster under the floor is a bit of a challange. I don't know if your's is under the floor or not, but that would probably be a reason not to use a booster for many of the truck owners on this site. Just guessing!
#18435 01/20/2005 2:30 AM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | Guys, after reading what you all say, it seems that patience and practice is what's needed. I have plenty of time, but I want to be back on the road by spring, so I guess I might give it a try. What kind of savings can be had by bending my own? new steel kit was around $145. I also heard that the bend over the rear end can be tricky? any thoughts on that?
Blue 50
#18436 01/20/2005 3:56 AM | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | blue50, just don't get in a hurry, get a tubing bender(available at your local parts store) and try not to make too sharp of bends. Another thing to remember is that it is easier to bend a line than it is to straighten it! Bend a little, check fit, bend a little, check fit, etc. I think anything you think you can do yourself, TRY IT! Much more rewarding, less expensive, and my theory in buying tools is..."If you need them once, you'll need them again." -tubing bender -tape measure -flaring tool(double inverted flare type) -protractor(not required, but helpful) just a note, remember to slide your flare nuts onto the line BEFORE you flare the end. If not, you get to cut it off and flare it again.
Keith If it were easy they'd have grade schoolers doing it! | | |
#18437 01/20/2005 3:59 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | The rearend can be tricky...save your old one when you take it off. If not, plan on taking your time and buy an extra length to do it again. Be prepared to bend some and when it starts to go bad, stop for the night ( or day or whatever)....
If you buy a kit, you will still have to do some extras for the double master....unless someone offers a kit for a double. I did not see one for my 46. | | |
#18438 01/20/2005 5:15 AM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | I too am considering a change on my 49. Looking at various vehicles in the junkyard, the one that caught my attention was an older Dodge van. It had a sideways mounted MC with a small (6-7 inch) dual action servo all mounted on a frame with a bellcrank from the brake pedal. It looks like the assembly would fit well under the floor, and the mount should be easy to modify. the big problem would be fabricating the pushrod from the original pedal to the servo, but that may not be that hard, either. Has anyone tried this approach before?
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
#18439 01/20/2005 8:31 PM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | The Filling Station has a complete bolt in kit [img]http://www.parts123.com/parts123/yb.dll?parta~showpic~0000014a~AAANV~~~[/img] http://www.fillingstation.com/ Frank | | |
