5 members (Donf, rfs56trk, DoubleB, BillCollins, Wally / Montana), 58 guests, and 3 robots.
Topics128,090
Posts1,056,022
Members48,430
#183918 06/17/2005 1:47 PM
Hi, I totaly new in this pickup but finally I had the money to buy two 1946 pickup-trucks .
I would like to convert 1 of them with a v8 set-up but because living in Belgium Europe , engines are hard to find, not to talk about gearboxes. Who can help me to supply me with a package ? Cheers
Jan
Don't waste water, drink wine !
1946 Chevrolet 1/2-Ton Truck
#183919 06/17/2005 2:34 PM
Putting a 350 in one of those trucks is not a "drop in" kind of deal, and i've not heard of a "package" or "kit" for that purpose.
Most folks who've done that conversion mention having to move the steering box, and having to do some chopping under the hood to get a bigger radiator to fit further forward.
Here's a link in the Tech Tips section to an article where a fellow swapped his stock 216 with a GMC 302.. not exactly swapping a 216 with a 350, but I would guess the same issues need to be addressed in the swap (perhaps just not with the same solutions)
TechTips Article on 216 to GMC302 swap
#183920 06/18/2005 7:33 PM
I've seen a 38 1/2 ton pickup with a V-8 and stock steering, but it sits up a bit higher between the frame rails than I prefer...
I'm using a mild 283 with a stock radiator that only gets too hot on very hot days in stop and go traffic.
Another quality post.
Real Trucks Rattle
#183921 06/18/2005 7:50 PM
I'm sure there is a 'KIT' for this swap. I'd contact Chevs of the 40s or Jim Carters. Also research the Hot Rod type mags on the news stand, filled with ads on the subject. Another option would be to clip the entire front end, giving you modern steering and the motor mounting you would need. I realize finding more modern Chevys as donor cars is not easy overthere. Just spend some time with research. Check out some of the vendors on this site that handle the Mustang front ends, should also have the V8 mounts.
1946 1/2-Ton Chevy
#183922 06/19/2005 4:46 AM
Chassis Engineering has the mounts. I had a friend with a 41 with a 327. I bought his radiator when he went to a camaro clip and aluminum radiator. The radiator uses the same mounting flange and tanks. It was just re-cored. It really helps my 216 stay cool.
Gravity - It's not just a good idea, it's the law.
#183923 06/20/2005 10:57 PM
Socket Breaker
Socket Breaker
Bill Gervais,
which one? One is in Florida, the other is in Iowa.
http://www.chassisengineeringinc.com/ <- Iowa <- I'm guessing this one since they do street rods.
http://www.chassisengineering.com/ <- Florida
anyhoo - thought I'd try to clarify.
-W
#183924 06/20/2005 11:04 PM
Thanks guys
This helps already a lot !
All the best !
#183925 06/21/2005 5:30 AM
The Iowa one.
To be long remembered as he's cruising in
The Passing Lane
