| | | Forums66 Topics128,014 Posts1,055,329 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 181 | Hi gang! I was just looking at my steering column and thinking about the horror stories of the early 60's vehicles columns going through the driver's chest in a collision. Is there a modern collapsable steering column I could pick up in a wrecking yard that would easily swap into a 62 c-30? Dave
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless! My 1962 Chevy C-30 | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | You might want to try a Jeep intermediate shaft. when I changed my column I put in a 85 camaro column that had a double D end. A jeep intermediate shaft is collapsable and also has double D end.
The intermediate shaft fit my column perfectly, it also has U-joints at both ends.
Worked for me and only cost $20.
Chris
Chris 1955FirstSeries
| | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | i believe a 67-72 c10 has a two piece shaft held still with plastic buttons. | | | | | Joined: Dec 2002 Posts: 3,437 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,437 | I've got a telescoping, tilt column out of a late 70's caddie in The Ox... along with three universals and short shafts to the steering mechanism.
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | The solid steering column was designed as part of an early passive restraint system in use before seat belts. They work under the same principle as an air bag holding you in the driver seat and preventing you from impacting the windshield.
Strenghtening of stomach muscles was recommended.
54 3100 with 235 62 flatbed dump C60 with 261
