Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
9 members (baldeagle, TexasJim50, ndkid275, Gone, RaNfLaS, JW51, Shaffer's1950, Donf, 1 invisible), 41 guests, and 3 robots.
Topics128,005
Posts1,055,253
Members48,418
#179232 09/13/2004 9:39 AM
Hi gang!
I was just looking at my steering column and thinking about the horror stories of the early 60's vehicles columns going through the driver's chest in a collision. Is there a modern collapsable steering column I could pick up in a wrecking yard that would easily swap into a 62 c-30?
Dave
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless!
My 1962 Chevy C-30
You might want to try a Jeep intermediate shaft. when I changed my column I put in a 85 camaro column that had a double D end. A jeep intermediate shaft is collapsable and also has double D end.
The intermediate shaft fit my column perfectly, it also has U-joints at both ends.
Worked for me and only cost $20.
Chris
Chris 1955FirstSeries
Z
Z Offline
i believe a 67-72 c10 has a two piece shaft held still with plastic buttons.
I've got a telescoping, tilt column out of a late 70's caddie in The Ox... along with three universals and short shafts to the steering mechanism.
Another quality post.
Real Trucks Rattle
The solid steering column was designed as part of an early passive restraint system in use before seat belts. They work under the same principle as an air bag holding you in the driver seat and preventing you from impacting the windshield.
Strenghtening of stomach muscles was recommended.
54 3100 with 235
62 flatbed dump C60 with 261
