3 members (homer52, Bill Hanlon, 1 invisible), 140 guests, and 3 robots.
Topics128,026
Posts1,055,408
Members48,422
#178465 04/25/2005 2:13 PM
I tried this over in the engine forum but no luck yet. My Father ran across a 4 spd. and called me wanting to post this to get some help on its ID. Here are all the numbers found on it and he says it has some sort of counter-weight on tail shaft. GM-128925856, C-22, 0293, 6261884. I hope this will help identify it.
Thanks in advance!
Mike
#178466 04/25/2005 3:22 PM
m. smith, i have a hollander interchange book it is a few yrs old but is up to date for our yrs of truck. if he would look at the numbers again they don't read like any gm that i could find. i would be glad to check more. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#178467 04/25/2005 4:40 PM
Mike.
Some of the four speed transmissions have the emergency brake mounted on the back of them. That is probably what the "counter-weight" is.
According to my 1963 shop manual, the unit number will be stamped on the rear of the case above the output.
Doug 57.
#178468 04/26/2005 1:52 AM
If it has the counterweight on the tailshaft it's probably a saginaw, from a vega/monza. Look at the input shaft and see if it has any grooves on it,that will tell you the gear ratios.
Tommy
59 apache 1/2t
261 short stepside
#178469 04/26/2005 2:11 AM
could not find any of those numbers in my hollander either..ron what edition do you have, picked up a 37th and 47 edition at a auction.just wondering thanks..mike j
Drive with Pride. mike j
family pic
#178470 04/26/2005 2:18 AM
Got some info. today that it came out of a '76-'78 Camaro. Don't know for sure but that's what a former owner said he took it out of.
Mike
#178471 04/26/2005 4:45 AM
If it came out of a car, it would have to be an M20 or one of the variants wouldn't it?
If you're interested in drive ratios, all the variants of the M20 are very close together.
Brian
#178472 04/26/2005 12:24 PM
It's definitely a counter weight, just a block of metal on tail shaft, not e-brake set up at all.
Mike
