9 members (Hotrod Lincoln, klhansen, 1955 1 Series, GradyB, Woodcmiami, Lightholder's Dad, TooMany2count, bowtietim, 1 invisible),
85
Mod | | | Forums66 Topics128,259 Posts1,058,335 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | All of you guys would be happy to know that the latest edition of Hot Rod Magazine has a build up of a 292 I-6 Chevy engine. They discuss the differences between the 194, 230, 250, and 292. They give names of parts suppliers. They discuss pistons, rods, intakes, carbs, exhaust, ect. I have not read the whole article yet, but I thought you guys might want to know that a mainstream publication is showing some love to stovebolts.
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Dec 2003 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 23 | Cool! Thanks for the tip. | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Just read the article. Guy at work brought it in. Good stuff. The EFI really added some HP to that 292 versus 4 bbl carb and Clifford intake. And the lump port head with small block valves flowed 40% better than stock. And speaking of stock, if I do well this summer on some recent stock (market) purchases, a 292 build will be happening this fall. -David | | | | | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | Thanks for the heads up Phil. I am going to go look for that issue. I have a 292 laying around the place somewhere that needs a going over. May as well do it right. Ralph | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | What issue was that? I looked on the newsstand, but couldn't find the article.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Highflyer,
It's the June issue. It must be. I went to one of the local Krogers and it had the May issue and there was nothing mentioned about the I6s.
-ftyler | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | My Barnes & Noble had the issue with the article today. | | | | | Joined: May 2005 Posts: 4 Junior Member | | Junior Member Joined: May 2005 Posts: 4 | Yes the June issue, page 108. Walt | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Thanks guys, I'll keep looking.
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I just skimmed the article this evening...good stuff. They mentioned some of the standard, but not often heard tips (using 283 and 307 pistons), as well as a few ones I hadn't heard (194/230/250 L22s use 5.7" small-journal connecting rods). They even talked about both versions, not just the 292 (although they didn't talk about the Poncho 250 OHC engines). | | |
