5 members (ShopRag, Wheelie, Ponchogl, wvstovebolt, 1 invisible), 72 guests, and 5 robots.
Topics128,258
Posts1,058,333
Members48,485
All of you guys would be happy to know that the latest edition of Hot Rod Magazine has a build up of a 292 I-6 Chevy engine. They discuss the differences between the 194, 230, 250, and 292. They give names of parts suppliers. They discuss pistons, rods, intakes, carbs, exhaust, ect. I have not read the whole article yet, but I thought you guys might want to know that a mainstream publication is showing some love to stovebolts.
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
Cool! Thanks for the tip.
Just read the article. Guy at work brought it in. Good stuff.
The EFI really added some HP to that 292 versus 4 bbl carb and Clifford intake.
And the lump port head with small block valves flowed 40% better than stock.
And speaking of stock, if I do well this summer on some recent stock (market) purchases, a 292 build will be happening this fall. wink
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
Thanks for the heads up Phil. I am going to go look for that issue. I have a 292 laying around the place somewhere that needs a going over. May as well do it right.
Ralph
rtlopez@shipleysystems.com
48 Chevy 3600 w/235
48 Chevy 3100 w/235:
You cant see the smoke on a dirt road.
The source for all the cool stuff
http://www.sissellsautomotive.com/
What issue was that? I looked on the newsstand, but couldn't find the article.
Highflyer,
It's the June issue. It must be. I went to one of the local Krogers and it had the May issue and there was nothing mentioned about the I6s.
-ftyler
My Barnes & Noble had the issue with the article today.
1954 GMC De Luxe COE
Junior Member
Junior Member
Yes the June issue, page 108.
Walt
Thanks guys, I'll keep looking.
I just skimmed the article this evening...good stuff. They mentioned some of the standard, but not often heard tips (using 283 and 307 pistons), as well as a few ones I hadn't heard (194/230/250 L22s use 5.7" small-journal connecting rods). They even talked about both versions, not just the 292 (although they didn't talk about the Poncho 250 OHC engines).
