| | | Forums66 Topics128,049 Posts1,055,674 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 209 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 209 | I asked this question awhile back. JUst dont remember what yall said. I have a 64 chevy short stepide c-10. I want to put a short box on it. Will the short box line up with the fame holes as the stepide? if yes does all the 60-66 short beds the same?
Stovebolt-It is painted
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | you have a short box on it already. Do you mean you want to put a short fleetside bed on it, in place of the short stepside bed? As far as I know the bolt holes line up the same... makes sense from an assembly standpoint. http://www.chevytalk.com - do a search in 60-66 trucks -it's prolyl floating around in there somewhere. -W | | | | | Joined: Apr 2003 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2003 Posts: 66 | yes the short fleetside bed and the short stepside bed have the same mounts and mounting holes.
Yes 60-66 beds are the same.
Joe - (Buckeye Bowtie) "Remember it takes about 2850 bolts to built a Chevy Truck and only 1 NUT to scatter them all over the highway"
1950 3100 1971 C-10 1939 Buick Century
| | | | | Joined: Oct 2004 Posts: 209 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 209 | Coo coo..Just makin sure guys.I am thinking about changing my truck into a fleetside. But i like the stepside too. Thank you Woogeroo and Buckeye.
| | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | the stepside mounts varied 62 to 63 because of frame width.www.mar-k.com has the details. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | zenish - ah yes... I forgot about that bit... good call.
so, Bambino if yer gonna swap get a '64-'66 bed... but keep in mind a '66 fleetside bed will have the reverse lights which became standard in '66. on '64 and '65 it was an option.
-W | | | | | Joined: Oct 2004 Posts: 209 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 209 | hhmm i thought that the 60-66 fit all the same. Weird. well thank for this tip
