3 members (Hotrod Lincoln, Ponchogl, 1 invisible), 40 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#175986 03/21/2005 5:46 PM
I asked this question awhile back. JUst dont remember what yall said. I have a 64 chevy short stepide c-10. I want to put a short box on it. Will the short box line up with the fame holes as the stepide? if yes does all the 60-66 short beds the same?
Stovebolt-It is painted
#175987 03/21/2005 7:21 PM
Socket Breaker
Socket Breaker
you have a short box on it already.
Do you mean you want to put a short fleetside bed on it, in place of the short stepside bed?
As far as I know the bolt holes line up the same... makes sense from an assembly standpoint.
http://www.chevytalk.com - do a search in 60-66 trucks -it's prolyl floating around in there somewhere.
-W
#175988 03/23/2005 1:03 AM
yes the short fleetside bed and the short stepside bed have the same mounts and mounting holes.
Yes 60-66 beds are the same.
Joe - (Buckeye Bowtie)
"Remember it takes about 2850 bolts to built a Chevy Truck and only 1 NUT to scatter them all over the highway"
1950 3100
1971 C-10
1939 Buick Century
#175989 03/23/2005 3:50 AM
Coo coo..Just makin sure guys.I am thinking about changing my truck into a fleetside. But i like the stepside too. Thank you Woogeroo and Buckeye.
#175990 03/23/2005 3:52 AM
Z
Z Offline
the stepside mounts varied 62 to 63 because of frame width.www.mar-k.com has the details.
#175991 03/23/2005 4:07 AM
Socket Breaker
Socket Breaker
zenish - ah yes... I forgot about that bit... good call.
so, Bambino if yer gonna swap get a '64-'66 bed... but keep in mind a '66 fleetside bed will have the reverse lights which became standard in '66. on '64 and '65 it was an option.
-W
#175992 03/23/2005 4:35 AM
hhmm i thought that the 60-66 fit all the same. Weird. well thank for this tip
