1 members (klhansen),
70
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Started doing my brakes today on my '65 3/4 ton. The fronts went pretty well and are almost done but, couldn't figure out how the rear drums come off. Anyone care to outline rear drum removal for a C20 for me? There are no steps in either the '63 or '65 manual. Also, there are no holes whatsoever in either front or rear backing plates to be able to turn starwheel. -David | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | maybe take the axles out first? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Just finished mine last night. First you have to pull the eight bolts in the center of the drum and remove the axleshaft from the drum. Then find the lock tab that's holding the outer locknut from turning. Take a punch and bend the tab away from the nut and remove the nut. Then remove the locking tag ring and remove the inner nut. The drum is now unattached from the rear diff but may still hang up on the shoes coming off. If it doesn't come off easily, give the drum some light raps of a BFH to break things loose. Good luck, Scott | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | I figured it was something like that. I had loosened up those eight bolts and it seemed to make the drum a little looser but, wasn't quite sure about the gear oil coming out and decided to ask before regretting something. So the lock tab and all that business is visible after pulling axle shaft out? -David | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | OK, I take that back about not being in the manual. It's under "Rear Axle" in the '63 manual, pages 4-35, 4-36 if anyone's interested or finds this post when searching in the future. -David | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Anyone know why my backing plates don't have access hole for starwheel? Looks like they should according to manual. -David | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | You have to knock the blank out and go buy a rubber plug to fill the hole, Scott | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | | | |
