2 members (Peggy M, Simso), 291 guests, and 9 robots.
Topics128,077
Posts1,056,034
Members48,433
#174990 05/29/2005 9:20 PM
would it be considered something of a "stovebolt sin", to put, say, a very nice 67-68 grill/hood set up, on a 69? i ask this because, you guessed it, my '69 grill is in pretty rough shape. and i have the 67-68 stuff. so, are there any like...advantages i guess, to this?
thanks!
.later days.
.desperado.
.sam.
1969 K20 , with a '67 front clip. fleetside. 292, 3x1 offy, headers. sm465 4spd. getting put back together, almost ready for paint.
doing it all myself.
19 and lovin' it.
"proper" is so over-rated.
.later days.
.sam.
Just that it will look better,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
thanks for the reply scott, but are you refering to the quality of the aesthetic part...or the overal design change from 67/68 to 69 and up?
thanks again.
.later days.
.desperado.
.sam.
19 and lovin' it.
.later days.
.sam.
You'll need to change the fenders and some of the inner structure also. It can be done, and I like the '67-'68 look better myself.
The radiator support needs to be swapped, too.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
hmm...fenders too? AND radiator supports? jeepers. does anyone know the fine details involved in this swap? thanks for the replys!
.later days.
.desperado.
.sam.
19 and lovin' it.
.later days.
.sam.
