| | | Forums66 Topics128,038 Posts1,055,590 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 95 Member | | Member Joined: Feb 2005 Posts: 95 | ok so the rain gutters when i bought my truck were filled with bondo, but it was cracking, so i took it all out.. now i noticed they were geting kinda rusty so i just hit em with naval jelly and sanded. Now i wanna fill them back up with something so that water doesnt sit, but i dont know wat substance to use: bondo, caulk, etc??
any help would be appreciated | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | What you need is a paintable "drip rail sealant" I am sure other's will chime in with their preferences and I am sure you can find good quality sealants at the local auto body paint shop. Here's one I found using the internet. Remember preparation is the key to avoiding failure. drip rail sealant | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | You didn't say which year truck you have but depending upon year, it could be a good idea to drill a small hole on each side to allow water to drain. Especially true on 60-66's. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | K-10,
You got that right, I always wondered why the factory did not put holes in our drip rails?????
Jake | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | They did, they look like little louvers on the front corners. They are so small though, they would need to be cleaned out often to be of any good, Scott | | |
